Old 25-01-10, 01:33 PM   #1
Neeja
Default Minor stumbling at small throttle openings
Quick one
New engine's in and running well (or as well as can be...) but it has a bit of an issue on tiny, tiny throttle openings. If you just barely crack the throttle at low RPM (Under 4000 or so), it feels like one of the cylinders is misfiring, with the bike jerking. No problems at all at higher RPM or throttle openings, no problems at idle.
There's currently an exhaust leak on the rear header (which I have the gasket to fix, just need a new front one to match), the throttle cables aren't routed well (but work), and there are no vacuum leaks that I can find. Spark plugs are new, and HT caps have been reattached to freshly cut leads. Any ideas?
Old 25-01-10, 04:33 PM   #2
Alpinestarhero
Default Re: Minor stumbling at small throttle openings
is it carbed or injected? If carb'd, check the carb balancing and choke is operating...if injected, then throttle body balance and TPS?
Old 25-01-10, 04:37 PM   #3
Sounds a tad lean, what have you got the carb low speed screws set at?
Old 25-01-10, 04:55 PM   #4
Neeja
Not a clue, YC, but I know that they're rounded off, because I had a looksee when they were off for cleaning a few months back, so doubt I can easily adjust them. For A*H, carbs are balanced and the choke's spot on - recently had the plungers out and greased 'em up good, plus packed the splitter with grease.
Looks like I may need me a big hammer.
Old 25-01-10, 06:40 PM   #5
Taipan
Taipan's Avatar
Having a similar problem. I thought mine was down to contaminated fuel but it isn't as I have a new tank and fresh fuel. When filtering through traffic at 4k revs on 1/8 to 1/4 throttle its really err lumpy. Open the throttle and it smooths out instantly. Its getting worse too so I suspect I'll find out the cause soon! Sometimes it clears too and you can really feel the difference, its much smoother and picks up cleaner and quicker as well. BMC filter dynojet and mixture screws 2.75 turns out. Picture of the plugs attached. Looks like one cylinder is richer than the other? I did put a new choke cable on and cleaned the plungers but the choke operation doesn't seem smooth?
Old 25-01-10, 11:21 PM   #6
embee
embee's Avatar
In my experience you really need to adjust the idle mixtures individually while the engine is running in order to get the "tip-in" just right. Setting to a specified number of turns is only approximate due to tolerances. The screws do need to be clean and free to turn, if they're not you'll have little success. It is a bit of an art, needs practice to get the feel.
Having said that, unless you have a right-angled drive adjuster tool, it's pretty tricky on an SV.
First obviously all the other adjustments need to be correct first, at the very least carb balance, no leaks, needles set in the right grooves, chokes closing off properly etc, and in a perfect world valve clearances too.
I have found a thin cotton/thermal type glove will let me get my hand in there just long enough to adjust the screws a bit before it gets too hot.
Practice while the engine's cold.
If all else fails, just richen them 1/4 turn and see what happens, if you stick to 1/4 turns and keep a note you can always go back where they were.
If you're stuck and can't make any progress, at least put in some iridium plugs, they are more tolerant of lean mixture excursions (rather the lean limit is extended a bit with them). They don't fix the problem but can make it easier to live with.
Old 25-01-10, 11:27 PM   #7
Neeja
Unfortunately for me, my mixture screws aren't going anywhere
Definitely no vacuum leaks, carbs were balanced very recently, choke definitely not sticking, valve clearances all within tolerances. The needle...not sure about, but it was never a problem before very recently....
The rear cylinder has an iridium plug in it. Unfortunately the front one I left in the old engine before it got sent back to the breakers, so it's got a standard one in there, but it was brand new and gapped correctly, at least.
Might have a bash at getting the mixture screws to move at the weekend, but I'm pretty sure they're fully rounded off. At the very least, I need to get the throttle cables routed properly anyway.
Old 26-01-10, 12:27 AM   #8
5hort5
If you want a spare set of carbs to try Neeja give me a shout I have a set in a box, not great but worth a go if you fancy it
5hort5 is offline   Reply With Quote
Old 26-01-10, 12:34 AM   #9
Neeja
Might be worthwhile. If you pass 'em over to me I can strip+clean them and then give 'em a go...worst case scenario then is you've got a clean set of carbs
Old 26-01-10, 12:39 AM   #10
5hort5
yer no probs, I brought them to take em to bits to see how they worked, on one of them the pilot screw will be out and erm not screwed back into the same position as I had a look to see what it was, basically I got em for a fiver cause I wanted to see what was what before taking mine to bits. Pm you your address m8 and I'll drop them off or pop round tomorrow after 7 to pick em up, I think you have my address. (or now if you're up lol)
Minor off.... keith_d Soho Massive 13 26-03-09 10:30 AM
minor sports injuries pencil shavings Idle Banter 20 10-01-08 10:07 AM
Ladies Bike gear - Small or Extra Small! StreetHawk Stuff Wanted 8 07-12-07 06:18 PM
Minor Scrape plowsie Bikes - Talk & Issues 20 09-11-07 12:20 AM
Minor drop :| Anonymous SV Talk, Tuning & Tweaking 5 01-05-05 01:54 PM
