Old 25-01-10, 11:22 PM   #1
warrenhewitt10
Default i have a silly dust cap problem
my mates bike has its mot 2morro and the back tyre pressure is very very low, we tried to take the cap off and its well and truely stuck on....
any ideas?? lol
weve tried mole grips and pliers to hold the bottom but dont want to try too hard for fear of wrecking the valve
Old 25-01-10, 11:22 PM   #2
simesb
Default Re: i have a silly dust cap problem
Tried heating it a little with a lighter (it looks like a metal cap)
Old 25-01-10, 11:29 PM   #3
warrenhewitt10
we had a hairdryer on it for a good while but no luck a lighter would be alot hotter tho i suppose
Old 26-01-10, 12:23 AM   #4
You're not alone in this - aluminium caps are well known for corroding in place.
Try a few sharp taps on the end of the cap to shock the threads, it's awkward as you need to hit it squarely on the end, and of course the hub is in the way, but it's worked a few times. Otherwise as the cap is aluminium and very soft in one stubborn case I managed to cut the cap off.
Old 26-01-10, 12:38 AM   #5
barwel1992
why not hold the bottom with pliers and the top with the grips and twist the top? or is that what you ment when you sead grips on the bottom
Old 26-01-10, 01:08 AM   #6
warrenhewitt10
yeh i tried that but it still didnt budge! didnt want to grip it too hard incase it splits!
does anyone know if a bike can fail the mot because of tyre pressure?
Old 26-01-10, 01:53 AM   #7
barwel1992
not sure but im sure they would try and pump it up if it was flat, so you could just see if they get it off when it goes in for the mot
Old 26-01-10, 02:52 AM   #8
beabert
what about curling tongs?
Old 26-01-10, 05:34 AM   #9
7755matt
Its not a reason to fail the MOT, however the tester is entitledto refuse to test the bike if he thinks the tyre is too flat to be able to safely test it
Old 26-01-10, 10:33 AM   #10
The Guru
Tried soaking it with WD of 4in1 spray?? Obviously try not get to much on the tyre
Another one bites the dust. Conrad Poons The Essex Lounge 19 23-04-07 07:29 PM
Dust Seals TSM Bikes - Talk & Issues 5 01-09-06 10:10 AM
another one bites the dust... but it doesn't put me off. GooseSVSK2 Bikes - Talk & Issues 18 13-05-05 12:30 PM
another one bites the dust... but it doesn't put me off. U.K.Ajay SV Talk, Tuning & Tweaking 11 04-01-70 03:40 PM
