Changed the oil and noticed there is a small oil leak coming from the right side of the bike where the stand is and the honda round bit at the bottom ....... Sorry dont know what it is called. Can anyone tell me a fix for this or is there a new seal neaded please help cause i am itching to get on the road xxx
Post a photo up?
Description hard to go on. Could need a gasket replacement? Hard to say. As Punch to the neck (fat neck) says pictures?
Hello mate, if the stand is on the right hand side I thing you will also find that the handlebars are behind you. They should be in front of you so unless Honda had a bad day when they put it together I would suggest you sit the other way round. Can't really help with the oil leak though unless you can be a bit more specific about where it is coming from. Which way up have you got the bike? Generally the black round bits should be on the ground.
Check around the clutch worm drive / pushrod area. The pushrod passes through some seals - these can deteriorate / wear/ be damaged and cause an oil leak
Honda nc24 1987 | PAGAN1001 | Bikes - Talk & Issues | 0 | 27-01-10 10:11 PM |
Honda nc24 1987 | PAGAN1001 | Bikes - Talk & Issues | 5 | 26-01-10 11:40 AM |
Honda vfr 400 nc24 | PAGAN1001 | Bikes - Talk & Issues | 3 | 25-01-10 05:23 PM |
Honda vfr 400 nc24 | PAGAN1001 | Bikes - Talk & Issues | 13 | 24-01-10 03:50 PM |
Honda vfr400 nc24 | BBadger | Bikes - Talk & Issues | 20 | 13-01-09 03:12 AM |
