Old 29-01-10, 12:29 PM   #1
Taipan
Taipan's Avatar
Question Non smooth brake lever action?
Hi All.
My front brake lever doesn't have a smooth pull when applying the front brake. It seems a bit notchy? I've cleaned and regreased the pivot bolt but still the action isn't smooth. So I've once again checked the pistons, calipers and pins but all are fine. Any ideas why the lever action isn't smooth when pulling the brake on?
Thanks.
Old 29-01-10, 12:31 PM   #2
Stig
Default Re: Non smooth brake lever action?
When was the last time the fluid was changed? It normally means either the hoses are flexing or there is air in the system.
Old 29-01-10, 12:42 PM   #3
jambo
jambo's Avatar
Have you removed the pin, and the lever, cleaning the surfaces of the lever, and master cylinder as well as just the pivot pin? Dirt build up would be my first thought.
Jambo
Old 29-01-10, 01:11 PM   #4
Spanner Man
Good afternoon.
When you're getting a slightly gritty feel when you pull the lever, it is often caused by a little corrosion under the rubber boot that's around the external end of the master cylinder piston.
Lift the boot with a suitable pointed tool, & get a squirt of silicone lube in there. I wouldn't use WD40 type products, as they could affect the master cylinder outer seal.
Cheers.
Spanner Man
Old 29-01-10, 01:12 PM   #5
Taipan
Taipan's Avatar
I dont know when the fluid was last changed. Its on the "to do" list but I was holding out until I've got some braided hose to replace the balloons with. Maybe I'll just give it a fluid change at the wekend.
Jambo
I removed the pin and lever but probably wasn't that thorough with the housing thinking about it. Another job for the weekend.
Thanks everyone.
Old 29-01-10, 07:01 PM   #6
Another common cause of such a problem is lever wear.
Remove the lever and look at the area that contacts the master cylinder's piston, is it worn flat? If so and if the damage is slight it is somtimes possible to gently re-shape the area with a fine file - but only if the damage is slight.
When reassembling carefully use a suitable grease on the contact point.
Old 01-02-10, 10:11 AM   #7
Taipan
Taipan's Avatar
I'll check that too. Many thanks.
Old 01-02-10, 11:23 AM   #8
MHP ltd
btw, on the adjustable levers you can disassemble them, where the pivot bolt goes through, theres a brass type tube, you can push that out too, clean, grease and replace.
it's fidly as there is a small spring keeping it under pressure.
Not sure if this will help your issue.
Old 01-02-10, 12:28 PM   #9
Taipan
Taipan's Avatar
Worth checking though, so many thanks.
Old 23-02-10, 07:37 PM   #10
richiekuk
I had the same issue with mine. it turned out to be the mating surfaces between the lever and the pivot point. I cleaned it up and greased it, and it was smooth as the preverbial baby's. For about a week when it got knotchy again.
I'm considering a new brake setup (maybe GSXR) master cylinder and lever.
Richie K
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Gear lever as rear brake lever? plowsie SV Talk, Tuning & Tweaking 2 29-05-07 05:23 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
Neither Brake lever works the brake light anymore kellie000 SV Talk, Tuning & Tweaking 13 29-12-06 12:15 PM
Seized brake pistons - best course of action? Dom_ SV Talk, Tuning & Tweaking 10 03-07-06 09:53 AM
