Old 29-01-10, 12:58 PM   #1
beabert
Default Charging circuit high voltage
Afternoon.
Since buying the thing ive noticed the starter motor seems to struggle a little then stop after a few seconds held on, the battery voltage was fine at 12.8, and i had fully trickle charged it.
So I switch it out with a friends new battery and its perfect, for some reason the battery must not be putting out enough current.
Anyway, i decide to test the charging voltage and i'm getting a steady 16.58v at idle building up to 16.8v further up the revs
Seems rather high, ill be doing a little research into it later, but i thought id ask those with more experience here too.
Can it damage the battery, any reasons to why its so high?
Thanks all.
Old 29-01-10, 01:04 PM   #2
Spanner Man
Default Re: Charging circuit high voltage
Good afternoon.
That's a touch too high methinks. It sounds like the rectifier regulator has gone up the pictures.
Charging voltage should be around the 14.5-15 volts maximum. Any higher will result in irreversible damage to the battery.
Cheers.
Spanner Man
Old 29-01-10, 01:10 PM   #3
beabert
Thank you, the manual says the same, ill rip seat surround off and test it cheers!
Should of bought a honda.
Old 30-01-10, 05:30 PM   #4
beabert
Anyone know if rectifier sh535c-12 the original suzuki one? Im replacing it ith one of a honda cbr, but i want to know if this is the genuine suzuki oe first.
TY
Old 31-01-10, 05:32 PM   #5
Alpinestarhero
I replaced my original faulty reg/rec with a suzuki OEM item; it seems to be a differant design to the one it replaced. so far, so good. I am touching some Pine saying that.
RST Voltage Gemaroo Suits 1 25-09-09 08:00 AM
No High Beam - but there is voltage (and yes the bulbs are ok...) chris7231 SV Talk, Tuning & Tweaking 8 25-03-09 12:28 PM
Crash.NET - Circuit-by-circuit with Dani Pedrosa. NewsBot News 0 04-04-07 04:10 PM
How do I check the charging circuit? thornton_chris SV Talk, Tuning & Tweaking 21 27-01-07 10:59 AM
Weird charging circuit values andyb SV Talk, Tuning & Tweaking 11 05-04-06 11:19 AM
