Old 30-01-10, 11:11 AM   #1
Vindaloo
Vindaloo's Avatar
Default Old oil shelf life?
I've some old oil lying around I'm thinking of using for an oil change this weeked. Probably about 4 or 5 years old.
Oil doesn't 'go off' right?
Adrian
Vindaloo is offline   Reply With Quote
Old 30-01-10, 11:18 AM   #2
Spanner Man
Default Re: Old oil
Adrian
I wouldn't use it, especially if the seal has been broken. Chemicals in the oil can degrade over time.
Splash out (pun interntional) on a new pot.
Spanner Man
Old 30-01-10, 11:21 AM   #3
tigersaw
tigersaw's Avatar
Default Re: Old oil
ProductShelf LifeBase Oils, Process Oils3 yearsHydraulic Oils, Compressor Oils, General Purpose Lubricating Oils2 yearsEngine Oils and Transmission Oils3 yearsIndustrial and Automotive Gear Oils2 yearsMetal Working and Cutting Oils1 year
Taken from http://www.carbibles.com/engineoil_bible.html
I have a gallon can of Castrol R30 - its over 30 years old and still ok
Old 30-01-10, 11:48 AM   #4
fastdruid
fastdruid's Avatar
Default Re: Old oil
Yes, yes it does. If unopened I wouldn't worry overly much about it, if opened then I wouldn't use it in my P&J.
Druid
Old 30-01-10, 03:52 PM   #5
Vindaloo
Vindaloo's Avatar
Default Re: Old oil shelf life?
Cheers guys. Actually had two bottles - one half empty which I'm binning (so to speak) and another sealed.
Got some new stuff to use.
Adrian
Old 30-01-10, 04:44 PM   #6
Alpinestarhero
This is interesting. I'm tempted to discuss with one of the analysis guys about doing some engine oil analysis - I have some old, but unused oil, laying about, adn I wonder how differant it is to new oil
Maybe in the future, I'll start doing my oil cnanges in an argon atmosphere...just need a big enough glove box to do it in...
Old 30-01-10, 05:45 PM   #7
Vindaloo
Vindaloo's Avatar
If you want some old oil to test with, I've just over 2 litres of very dark looking stuff from just before Chirstmas you can play with.
Pretty sure that when it's only been in the engine for three months and done just over 300 miles it shouldn't be that dark. Which surely must mean that it's special oil ... or that the insides of my engine are filthy.
Adrian
Life plowsie Idle Banter 53 09-09-09 06:30 PM
Tyre Shelf Life? dizzyblonde Bikes - Talk & Issues 1 28-07-08 06:38 AM
Its life Jim, but as we know it! DanDare Idle Banter 5 23-01-08 02:59 PM
Where I can get a sucker feet piggy off the shelf? monkey Soho Massive 3 21-12-07 10:58 AM
Anyone knoe where one can get Philips Xtreme bulbs off the shelf? monkey Bikes - Talk & Issues 21 08-11-07 10:07 PM
