Old 30-01-10, 02:02 PM   #1
Supervox
No more Mr Nice Guy
Supervox's Avatar
Default IT Help Req'd - Dual Boot
Could some kind person provide me with an idiots guide to setting up a dual boot system ?
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 30-01-10, 02:04 PM   #2
beabert
Default Re: IT Help Req'd - Dual Boot
what are you dual booting
Old 30-01-10, 02:20 PM   #3
fastdruid
fastdruid's Avatar
If you want linux/windows then just install windows first and then install linux, it'll do it for you, if you want windows/windows its trickier. As beabert says, what are you trying to do?
Druid
Old 30-01-10, 04:06 PM   #4
Supervox
No more Mr Nice Guy
Supervox's Avatar
See, told you I needed an Idiot's Guide !!
I want to be able to run XP Pro (current OS) but also have the option to run Windows 98.
In case you think this is bizarre, the reason is that I have a little project to do as a favour for someone that involves writing a piece of music & my software (Cubase 3.7) runs best with W98.
Before anyone suggests updating the software to a more recent version - this isn't an option at this time I just can't justify the expense !!
Old 30-01-10, 04:10 PM   #5
jambo
jambo's Avatar
It's not exactly thrilling reading but this might be worth looking at: http://support.microsoft.com/kb/306559
Jambo
Old 30-01-10, 04:28 PM   #6
beabert
Of the top of my head i would create two partitions. Installing xp last, then use software like easy bcd to create a boot menu, or manually edit the boot.ini.
personally, I would just 'obtain' a version of cubase for use in xp it if was me, or use a trial. PM me and ill see what i can do.
Old 30-01-10, 04:30 PM   #7
Spikenipple
Spikenipple's Avatar
Why don't you get a newer version of Cubase? 3.7 is ollllld school!
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 30-01-10, 04:37 PM   #8
Supervox
No more Mr Nice Guy
Supervox's Avatar
From my original post !!
3.7 maybe 'old school' as you put it - but it's what I have & what I've been working with for the past 15 years; I know how to get the best from it & I like it !!
I'm sure I would love Cubase 5 but at the best of part of £500 I can't justify it.
Old 30-01-10, 06:21 PM   #9
fastdruid
fastdruid's Avatar
Seriously I wouldn't bother. I'd run Windows 98 in a VM.
Otherwise you need to wipe XP, repartion, install Win98 and reinstall XP.
Druid
Old 30-01-10, 06:28 PM   #10
vjones777
This is the best guide I've ever seen - very comprehensive. If you take to time to read it you'll understand the issues and will have no problems. http://www.goodells.net/multiboot/
As he explains Windows98 has some peculiarities.
Installing a virtual machine is another idea but you'll need a PC with some horsepower - if its a recent machine it should be ok if you have a gigabyte or more of memory. One snag with 98 on a virtual machine is that you'll probably be limited to a low screen resolution (640x480 I think) as 98 doesnt support virtual machine extensions. At least thats true with VMware. Virtualbox might be better, but I havn't tried that.
IT Help req'd Supervox Idle Banter 8 16-07-09 09:19 AM
Visual Basic help req'd Supervox Idle Banter 6 22-06-07 10:56 AM
HELP !! IT Bod req'd !! Supervox Idle Banter 17 17-04-07 01:31 PM
fork oil 15 or 20? advice req'd. will SV Talk, Tuning & Tweaking 11 20-06-05 07:16 PM
radiator problem? help req'd. will SV Talk, Tuning & Tweaking 4 15-04-05 07:24 PM
