Old 31-01-10, 02:53 PM   #1
sv-smc
Default clutch cover seal (oil leak)
hi all been a member 4 a while now but never posted anything. i have a oil leak coming from my clutch cover it seems i need a new seal its a big o ring does anyone know if and where these r availible. thanks
Old 31-01-10, 02:55 PM   #2
Default Re: clutch cover seal (oil leak)
Seal is probably fine, it is the cover itself that warps.
Old 31-01-10, 02:56 PM   #3
husky03
part number-11484-19F00
buy from-
http://www.robinsonsfoundry.co.uk/sh...rts/index.html
Old 31-01-10, 02:58 PM   #4
fastdruid
fastdruid's Avatar
Yes & Suzuki.
It seems sometimes however the problem is the cover itself has warped and a new O-ring will do nothing, in which case you either need to swap the entire thing for a pointy cover or replace the cover.
Worth mentioning you should also be careful how you tighten it, should always tighten opposite bolts and a bit at a time. Working in a star kind of pattern like this.
Druid
Old 31-01-10, 03:00 PM   #5
sv-smc
thanks 4 advise will have a look around
Old 31-01-10, 05:01 PM   #6
beabert
Just use some gasket maker ontop and around the oring.
Old 31-01-10, 05:07 PM   #7
5hort5
And not over torque them and snap a bolt off like i did. Just a bit tighter, just a bit more, snap - ****!
5hort5 is offline   Reply With Quote
Old 31-01-10, 05:16 PM   #8
Overtightening can cause leak in first place
Old 31-01-10, 05:22 PM   #9
5hort5
yep 10nm if memory serves for those bolts - it's one of those that you remember after doing it
Old 31-01-10, 06:47 PM   #10
sv-smc
might b a good idea for me 2 get a small torque wrench then. i have a big 1 that i use 4 the rear wheel but doesn't go low enough for the smaller stuff
rocker cover seal noob-saibot SV Talk, Tuning & Tweaking 5 29-01-09 09:34 PM
The never ending clutch cover oil leak badger-666 SV Talk, Tuning & Tweaking 3 20-02-08 07:25 PM
leak from right-hand crankcase/side cover- common problem ? chriskk SV Talk, Tuning & Tweaking 9 09-10-07 11:27 AM
Curvy SV650 clutch cover oil leak bugsy46 Bikes - Talk & Issues 1 06-04-07 11:28 PM
Oh dear- leak from front sprocket shaft seal? northwind SV Talk, Tuning & Tweaking 12 12-05-05 02:47 PM
