Old 01-02-10, 07:03 PM   #1
Nobbylad
Nobbylad's Avatar
Default GSXR Front end mods
I know there are loads of GSXR front end threads, but I have a specific question....has anyone done a late model Gixer front end upgrade i.e. K7 onwards (600/750 or 1000)?
Ta
Old 01-02-10, 07:05 PM   #2
fastdruid
fastdruid's Avatar
Default Re: GSXR Front end mods
No difference really apart from the steering lock between the K5/6 GSXR1000 and the k6+ 600/750.
What do you want to know?
Druid
Old 01-02-10, 08:11 PM   #3
BillyC
BillyC's Avatar
On the face of if it, yes that's more or less the dilema of the K6+ front ends - the steering lock won't work. It's possible there might also be some issues with steering stops might be off too...
Electrics... if you're planning on using the Gixxer switches at all, then there may be some extra issues. My K4/5 front end needed a little tweaking, but worked out nicely.
Old 01-02-10, 08:17 PM   #4
Nobbylad
Nobbylad's Avatar
I have a K7 1000 set of forks/yokes/calipers and was basically wondering if there was anything I needed to think about other than where the chuff to get a front wheel from!
Have got the TLS1000 clip ons and the magnets for the speedo conversion, just need to find a front wheel, but also considering jacking it in....wouldn't be the 1st time I bought a set of Gixer forks then jibbed them again because I changed my mind!
(Then again....I do like the black & gold forks)
Old 01-02-10, 08:58 PM   #5
Nobbylad
Nobbylad's Avatar
BTW - put this together during my quest for wheel/disc and other useful bits in an attempt to understand what's compatible across models/years...hope it's useful!
Old 01-02-10, 09:31 PM   #6
CheGuevara
Ta
Yup - K7 750:
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 01-02-10, 10:53 PM   #7
Red Herring
Red Herring's Avatar
Originally Posted by CheGuevara View Post
Yup - K7 750:
What did you do with the clocks, I was under the impression the pointy needed it's clocks to run.
Old 01-02-10, 10:59 PM   #8
CheGuevara
That pic was while I was still putting it together(best close-up of the forks). I've made a lightweight Al bracket for the clocks, moved the headlight down a bit:
Old 02-02-10, 10:23 AM   #9
Red Herring
Cheers, thought I'd missed a trick there!
[MODS] Aftermarket Front Indicators phizog SV Talk, Tuning & Tweaking 0 29-06-08 07:29 AM
All this talk of front end mods... amnesia SV Talk, Tuning & Tweaking 12 15-05-08 09:34 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
