Old 14-02-10, 01:54 PM   #1
mattb200
Default Clutch "mechanism"
afternnoon
just changed the clutch cable on sv650sk3 and whilst doing this noticed how little movement actually occurs when you pull the cable. what i mean is the rod that this is attached to and goes into the engine seems to actually only move 2mm so - surely thats not enough movement?
Old 14-02-10, 01:56 PM   #2
Richie
fantabulas
Richie's Avatar
Default Re: Clutch "mechanism"
have you adjusted the cable correctly?
My Flickr photos
Old 14-02-10, 01:58 PM   #3
It needs way less than 1mm to break the clutch pack and allow slip.
Old 14-02-10, 02:00 PM   #4
mattb200
yeah seems ok. i assume it must have always been like this, just wanted to know how much 'lateral' movement that bar/rod (sorry don't know what its called) should have when clutch engaged/disengaged?
Old 14-02-10, 02:01 PM   #5
Whatever it takes to operate the clutch, don't worry about the actual amount of movement there so long as it is smooth and works ok.
Old 14-02-10, 02:01 PM   #6
mattb200
so its normal then?, thanks YC you put my mind at rest if thats the case.
Old 14-02-10, 02:03 PM   #7
mattb200
thanks for this much appreciated.
Old 14-02-10, 02:07 PM   #8
Richie
fantabulas
Richie's Avatar
Yorkie_chris beat me too it.
My Flickr photos
Old 14-02-10, 02:12 PM   #9
mattb200
thanks Richie, sorry maybe i was not clear, l was talking about the amount of movement that the bar attached to no 3/4 in that diagram made. YC has put my mind at rest though! thanks anyway.
eye ball yellow "n" and a blue "s" curvey!!! cymroboi The Border Patrol 5 19-06-09 08:09 PM
Curvey "N" clutch lever mount Jase22 Stuff Wanted 1 02-09-07 09:18 AM
"Open" Clutch Cover - FOUND THEM !!!! :-) Noufy SV Talk, Tuning & Tweaking 16 07-09-05 10:31 AM
"creaking" sound from clutch when cold branny SV Talk, Tuning & Tweaking 6 09-08-05 09:15 AM
