Old 15-02-10, 11:45 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default New bits (Land Rover) and painting advice
Here's my sliders for my 300tdi Disco.
Got them for £60 and a fella I know got them shot blasted for me as they needed it.
Now then, how to paint them. Was planning on a big tub of black hammerite but what to use as a base coat(s)?
How to amuze an idiot:
Look right-> <-Look Left
Old 16-02-10, 12:39 AM   #2
5hort5
Default Re: New bits (Land Rover) and painting advice
Powder coat em - finish will be miles better
5hort5 is offline   Reply With Quote
Old 16-02-10, 12:43 AM   #3
+1
Old 16-02-10, 12:52 AM   #4
Mr Speirs
Mr Speirs's Avatar
more hammerite???
Old 16-02-10, 07:50 AM   #5
shifter
I wouldn't bother with Hammerite, ok you can keep slapping it on as and when but you can't paint anything else over it if you change your mind.
I would get them powder-coated in black, much more durable and will look the nuts.
Powder-coating can be surprisingly cheep as well.
Old 16-02-10, 07:58 AM   #6
454697819
hammerite is a base coat and top coat in one,
Powdercoating is better but how bashed are they going to get as it can chip then its difficult to repair.
Old 16-02-10, 10:05 AM   #7
_Stretchie_
Large Member
Powder coating may end up being a waste of money to be honest. These things go under the sills on the side of the vehicle so when I go over rocks or around trees and things these things take the impact instead of the car so they'll only end up getting scrapped alot.
I may be a tart but not a fashionable one so these would just get done black and as the paint gets scraped off and rust begins to appear, a run down and recoat in the affected area will be the remedy.
But thanks for the ideas guys.
Oh mighty org I thank you...
Old 16-02-10, 10:13 AM   #8
Richie
fantabulas
Richie's Avatar
Black sticky grease... easy to apply and keeps rust down, and helps sliding over rocks. just mind your frock getting in and out of the vehicle.
My Flickr photos
Old 16-02-10, 01:40 PM   #9
_Stretchie_
Large Member
I WILL NOT risk my frock
Old 16-02-10, 01:40 PM   #10
lily
Where you going to put the xmas trees?
Painting advice liamsimpson SV Talk, Tuning & Tweaking 7 24-11-09 06:34 PM
Rover coupe spoilers... BanditPat Idle Banter 0 04-10-09 08:34 PM
rover 400 for not a lot! chris8886 Idle Banter 19 13-01-09 08:05 PM
Spray painting - beginner needs advice stuballs Bikes - Talk & Issues 7 14-12-08 01:07 PM
london to weegie-land...route advice needed emcf Bikes - Talk & Issues 2 23-05-07 08:01 PM
