Old 17-02-10, 05:57 PM   #1
metalhead19
Default Fitting new exhaust
Sorry if this has been posted before, earler today my street extreme arrived and it says to use a little bit of silicon on the joints, is it necessary to do this? Or would some lock tight be usable?
Dan
Old 17-02-10, 06:00 PM   #2
Default Re: Fitting new exhaust
Not loctite, you can get little tubes of exhaust sealant, but see how it fits first, you probably won't need any
Old 17-02-10, 06:03 PM   #3
The silicon sealant is to do just that - seal the joins. Locktight comes in tiny, (and expensive!), amounts, and isn't suitable for the task.
That said if you have no suitable sealant and don't wish to buy any, and assuming it's just an end-can you're fitting, then fit it and see if it leaks, the chances are it'll be fine without sealing it.
Old 17-02-10, 06:04 PM   #4
metalhead19
Ok thanks for the reply. I did wonder if it was worth getting the silicon as any online fitting instructions had not mentioned it.
Old 17-02-10, 06:05 PM   #5
metalhead19
And yes is just an end can
cheers
Exhaust fitting thebug Bikes - Talk & Issues 0 20-09-09 12:50 AM
Fitting r6 exhaust. Pukey SV Talk, Tuning & Tweaking 13 20-08-09 03:01 PM
Fitting A New Exhaust sid99 SV Talk, Tuning & Tweaking 28 03-10-08 07:17 PM
Exhaust fitting. Smoggy SV Talk, Tuning & Tweaking 17 18-09-08 04:54 PM
ART Exhaust (fitting) xlewdx Exhausts 8 17-12-06 07:06 PM
