Old 19-02-10, 02:41 PM   #1
warrenhewitt10
Default How do you test a flasher relay?
as the title says, how would i go about testing the flasher relay on my 125cc Bike? its indicators have recently given up....flick the switch and just nothing, same with the hazard lights!
Old 19-02-10, 02:50 PM   #2
tigersaw
tigersaw's Avatar
Default Re: How do you test a flasher relay??
If its an old school 2 pin jobbie, I'd remove it, short across where it was and the lights should come on, but not flash.
If not, then flasher not at fault, if so, then further test flasher out of bike
Old 19-02-10, 04:19 PM   #3
Dave20046
Dave20046's Avatar
As above, however I'm pretty sure that indicates something else as the hazard lights get their flashy flashy from elsewhere IIRC.
Old 19-02-10, 08:13 PM   #4
Nope same place, just the switch for those turns both on at once, it's not a separate relay or owt. (on the SV)
Old 19-02-10, 08:15 PM   #5
Dave20046
Dave20046's Avatar
Ah, think I know why. I had a faulty led flasher unit and the hazards still flashed - I guess they must have been still using the sv's multifunction relay and I'd only removed the indicators wires from it?
Sorry for the inaccurate info anyhoo.
Old 19-02-10, 08:29 PM   #6
I thought all that business was on your curvy?
Old 19-02-10, 08:34 PM   #7
Dave20046
Dave20046's Avatar
both (just don't think I rang you about the pointy )
Old 19-02-10, 11:53 PM   #8
carternd
If not this go through the indicator system from the switch to the bulbs. As previously stated, hazards (if you have them) are almost certainly from this relay. Check headlight/brake light and starter motor first though. Just in case the main fuse has gone.
Old 20-02-10, 09:31 AM   #9
warrenhewitt10
ok guys cheers! i shall check that later! its a chinease 125cc "Chituma" so anythings possible
Old 20-02-10, 03:28 PM   #10
Dave20046
Dave20046's Avatar
Ah, it needs putting in the bin then.
Where is my flasher relay(s)? Lost@Home SV Talk, Tuning & Tweaking 5 30-01-10 02:51 PM
How to Wire Hein Gericke Flasher Relay BomBalong SV Talk, Tuning & Tweaking 7 30-08-09 04:11 PM
problem with flasher relay. fourstrokebeast SV Talk, Tuning & Tweaking 10 30-03-08 07:22 PM
WANTED asap flasher/multi function relay sv650k4 Stuff Wanted 6 24-01-08 09:59 PM
Flasher Relay installation - might have done something bad... R-Razor SV Talk, Tuning & Tweaking 7 07-10-07 12:28 AM
