Old 19-02-10, 08:08 PM   #1
sv650nutter149
Default streetfighter project - fuel light
hi all im currently doing a streetfighter for a mate but after having dif clocksd put on this has now left him without a fuel light. i know there is a sensor in the tank but does anyone know how to wire a new one in?
cheers
ian
Old 19-02-10, 08:12 PM   #2
fastdruid
fastdruid's Avatar
Default Re: streetfighter project - fuel light
You'd have to make up some kind of circuit to do it, the sensor is IIRC a three wire sensor that has two different resistances that change when the petrol level falls under certain levels. You can't just attach a bulb.
Druid
Old 19-02-10, 08:37 PM   #3
Sean_C
I can't remember exactly what I did (could probably find out) but as its two sensors I wired up two lights for it- straight off the SV loom. If you look at the SV wiring diagram in Haynes you can figure it out (I managed to).
Old 19-02-10, 09:32 PM   #4
phi-dan
phi-dan's Avatar
http://forum.svrider.com/showthread.php?t=103092 or
http://forum.svrider.com/archive/index.php/t-45256.html
These any good?
(I;ve been reading up a lot on fuel sensors since mine turned out to be broke)
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 20-02-10, 09:07 AM   #5
sv650nutter149
it kinda makes sence will just have to see
Eden Project Blue Light Weekend Fri 5 - Sun 7 Feb phi-dan South & West Surfers 0 04-01-10 02:40 PM
Eden Project Blue Light Weekend phi-dan South & West Surfers 0 28-10-09 02:12 PM
Fuel Light Ceebl Ancillaries 12 11-12-08 10:48 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
