Old 20-02-10, 09:21 PM   #1
Default Fitting GSXR front mudguard to GSXR USD forks
Need a bit of help here. Just fitted my front mudguard to my USD forks, steel fork brace is in place and I can do up the rear bolts ok
But I'm a bit puzzled how the front attaches?
On the Alphasports parts fiche it shows a bolt and a washer, which looks like it has a collar on it to reduce to hole size. Then the bolt I presumne is meant to pass through the hole of the steel brace? Then the bolt secures to the boss on the bottom of the fork leg.
I've got the brace in the correct place, as the brake hose guides are as they should be on the parts diagram
At the moment I haven't resorted to force, as the mudguard has just been sprayed.
I can't find any good pictures on the net at the mo. The brace is correct for the mudguard.
Any of your pics would help. I'll post some tomorrow
Old 20-02-10, 10:05 PM   #2
Default Re: Fitting GSXR front mudguard to GSXR USD forks
No need to bother, as I have found that 2 brackets to attach the mudguard to each fork leg are missing.
So off to my dealer on Monday with a list or Robinsons Foundry have them
GSXR 600 k1-k3 Front Mudguard. hindle8907 Stuff Wanted 4 04-09-09 12:08 AM
COMPLETE FRONT END-GSXR 750 K5 forks 21QUEST For Sale - SV's and SV related items 23 23-06-09 04:56 PM
GSXR front forks onto a Curvy mike_red2uk SV Talk, Tuning & Tweaking 12 21-03-09 03:57 PM
GSXR Front Mudguard from 750 Y - K3 or 1000 K1 - K2 Stu Stuff Wanted 6 12-06-07 02:22 PM
Gsxr Forks Mudguard Mounting gruff SV Talk, Tuning & Tweaking 0 01-05-07 08:53 AM
