Old 22-02-10, 04:17 PM   #1
Essex-Tacy
Default Throttle Slide/Electrical Wire
Hi was just curious as to anyone was breaking an Sv650 99-02, as Im after a throttle slide as I snapped my one taking the accelerator cable out of it.
There was also a wire that connects from the bottom front from the front of the engine, not exactly sure what the cable is, but it sort of almost connected directly to the battery, so possibly alternator!?????
Anyways if anyone has these parts for sale, a PM would be most appreciated,
Cheers.
Old 22-02-10, 04:19 PM   #2
Default Re: Throttle Slide/Electrical Wire
Throttle slide? Woot? SV cables do not connect to the slides.
Old 22-02-10, 04:20 PM   #3
Essex-Tacy
Ermmm maybe there not called slides, Il try weird circular white thingy on the handle bars
Old 22-02-10, 04:22 PM   #4
Twistgrip
That wire sounds like starter motor wire, does it go from the front of the motor to a green box under right hand side seat infill panel?
really thick chunky wire?
Old 22-02-10, 04:31 PM   #5
Essex-Tacy
Possibly Il have to check when I get home from work!!
Twistgrip ahhhhh thank you very much Il add that to my motorbike termonology
Old 22-02-10, 04:31 PM   #6
There is only one really thick wire goes to the front of the motor. Other wire much smaller is oil pressure sender.
Old 22-02-10, 05:35 PM   #7
fastdruid
fastdruid's Avatar
Remember to use a very thin 10mm spanner to hold the lower nut when you remove the cable from the starter motor. Otherwise its very easy to twist the terminal on the starter, break the plastic insulator and junk the starter (you can get a rebuild kit but cheaper to buy a s/h motor).
Druid
Water slide jump maviczap Idle Banter 4 05-09-09 04:14 PM
Restrictor slide/washers benjyman Stuff Wanted 0 18-09-08 10:48 PM
Unbelievable Slide! lukemillar Racing and Paddock Chat 10 20-08-08 05:40 PM
samsung sgh-g600 slide mobile for sale ging6996 Idle Banter 0 27-07-08 05:52 PM
carb slide flutter mregehr SV Talk, Tuning & Tweaking 3 27-03-06 11:27 AM
