Old 05-03-10, 04:14 PM   #1
ahmedf
Default new tyres wheel balancing issue help?
I just had some avon storm ultras fitted. The rear went on fine got balanced all ok.
However the front when put on the machine needed a 25 gram weight and a 90 gram weight. My mechanic was shocked. So he deflated tyre rotated the tyre around the rim 180 degrees and balanced again but this time it came to 75 grams instead of 90. he was still shocked and put the weights on and said report back as he was still not convinced.
Now at speeds of 30+ and also under harsh acceleration theres is notable shake in the steering and naturally gets worse the quicker i go.
went back to him today and he said take the weights off and see how it is, still shaking. i'm taking it back to him on tuesday but any help as to what the problem is would be great. Could it be a duff tyre?
its a k9 sv650s btw.
thanks
Old 05-03-10, 04:16 PM   #2
Luckypants
Luckypants's Avatar
Default Re: new tyres wheel balancing issue help?
Indeed that sounds like a bad tyre, your fitter should take it off and fit a replacement, send that one back to Avon as a dud. If with all those weights on it, it still does not run balanced, then it is not fit for purpose / of merchantable quality IMO and should be replaced FoC.
Old 05-03-10, 04:18 PM   #3
fastdruid
fastdruid's Avatar
I came across this the other day which makes interesting reading re wheel / tyre balancing.
http://www.peterverdonedesigns.com/mctires.htm
Druid
Old 05-03-10, 05:02 PM   #4
Spanner Man
Good afternoon all.
Before condemning the tyre, have you tried balancing the wheel without the tyre fitted? I have come across cases where it's a wheel issue, such as worn bearings that cause an excess of weight to be required to achieve a good balance.
Cheers.
Spanner Man
Old 05-03-10, 05:03 PM   #5
punyXpress
punyXpress's Avatar
Can't fathom out why wheel imbalance is at anything other than at the valve or 180 degrees away. Unless it is affected by brake discs?
Now: Street Triple R
Old 06-03-10, 10:07 AM   #6
Originally Posted by Spanner Man View Post
worn bearings
First thing I'd check in this circumstance.
Few wheels alone are bang on balance, but they're rarely far off, and where that imbalance is varies.
Old 06-03-10, 10:10 AM   #7
ahmedf
cheers for the replies, will ask my mechanic to look into all ofthe issues raised.
however you really think it would be bearings, considering its just under 1.5 years old?
cheers
Old 06-03-10, 10:32 AM   #8
It's certainly not a long life, but, stranger things have happened.
Changing and balancing your own tyres – How to. Berlin Tyres 8 17-08-10 12:36 PM
Car Wheel Balancing -Ralph- Idle Banter 20 21-10-09 06:54 AM
wheel balancing on yer bike SV Talk, Tuning & Tweaking 0 06-06-09 03:25 PM
Wheel balancing cuffy SV Talk, Tuning & Tweaking 14 12-01-06 08:02 PM
Balancing and fitting tyres northwind Bikes - Talk & Issues 12 27-01-05 08:22 PM
