Old 07-03-10, 04:56 PM   #1
Caddy2000
Default So what do you all think of DID chains?
I can get a DID x ring chain and steel sprockets for £95.
Any thoughts?
Old 07-03-10, 04:56 PM   #2
Alpinestarhero
Default Re: So what do you all think of DID chains?
Go for it. They are one of the more respectable brands
Old 07-03-10, 05:19 PM   #3
Lozzo
Best chain available, definitely buy it at that price
Old 07-03-10, 08:54 PM   #4
Spanner Man
Good evening all.
DID, like all chain manufacturers make several different grades of chain in each size. So, the value of a C&S set depends on what grade of chain is supplied with it.
I personally prefer Tsubaki. As, I find they last longer than the equivalent DID on a £ for £ basis.
Cheers.
Spanner Man
Old 07-03-10, 09:04 PM   #5
Dave20046
Dave20046's Avatar
Spannerman, do you know how you can obtain the grade of the chain?
Old 07-03-10, 09:08 PM   #6
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Not sure if your aware but on fleabay can get a DID X Ring & Sprocket kit for £75.
Here is one.....
http://cgi.ebay.co.uk/DID-X-RING-Cha...#ht_1376wt_736
Then leaves you £20 better off for beers!!
"Feckinnnn Unluckkeeeeeeee"
Old 07-03-10, 09:19 PM   #7
Lozzo
X-Ring is only available in DID VM and ZVM chains, which are the top two grades. I ought to know this, I was a sales rep for the DID importers for a couple of years
Old 08-03-10, 07:42 AM   #8
Spanner Man
Good morning all.
I believe DID call their economy chain VX the higher grade one VM, & their premium one ZVM. I had a quick look on their website, & some of the info is on there.
However, don't get confused by all the X ring versus O ring twaddle. There's a lot more to chains than that.
Some years ago there was an issue with DID VM grade chain, in 520 & 530 sizes. They were cracking on the sideplates. Both DID & Bickers (the importer), were frankly downright appalling in their attitude towards the problem, & I have avoided using DID ever since.
I have found that Tsubaki chain is equally as good, & slightly more reasonably priced too.
Cheers.
Spanner Man
Old 08-03-10, 09:25 AM   #9
Caddy2000
Thanks for all your feedback. I was originally going to go for a Tsubaki chain and steel sprocket set, and I think I might still go down that route.
I can get a chain and sprocket set from B+C for £108 (don't know about delivery), any other decent companies out there?
Paul
Old 08-03-10, 09:48 AM   #10
Spanner Man
Paul
Good morning all.
Go for Tsubaki SG chain. It's a little more expensive, but worth it.
Cheers.
P.S. I'm currently doing them for £115
Spanner Man
Old Chains PoRk ChOp Idle Banter 10 13-01-10 10:13 AM
Chains...... BanditPat Idle Banter 15 27-06-09 01:54 PM
Chains Draper Bikes - Talk & Issues 19 10-06-07 11:14 AM
chains weazelz SV Talk, Tuning & Tweaking 3 16-10-06 11:30 AM
Chains diamond SV Talk, Tuning & Tweaking 13 16-03-05 03:55 PM
