I have read many battery/ reg rec posts on here including Nadines super-thread but i'm still not sure whats going on so please help....
My bike is a 2000 sv650s with 37k miles and a datatool alarm, and ive owned it since last May. Towards the end of the summer it had intermittent starting trouble so it's been on a trickle charger through winter, ridden regularly (100 miles yesterday no problem) and always started first time like that... until today. I rode 50 miles, then stopped for an hour then rode about 60 more and stopped again, lights on all the time as that is how i ride. Except after the second stop it was immediately obvious the bike wasn't starting. Thankfully the EAR lads were on hand to bump start it, i rode 15 further miles (lights off) before having to stop to re-fuel, after which it started fine!! I've just been out with the multi meter, having recharged the battery, and got the following readings: Battery off the bike 13.08v Battery on the bike at idle speed 13.40v Battery at 4k rpm fluctuating between 8 and 9v!!! (All wiring looks ok to my uneducated eye.) From what i've read it shouldn't be below 12v so obviously my bike has issues. I assume (maybe incorrectly) that the battery is fine as it is charging, please confirm that it's a new reg/rec i need. Thankyou xx |
You need to check the alternator output as well.That is the AC voltage across the three yellow wires that come out of the alternator and go to the reg.Check them 1&2 2&3 and 1&3.All should produce similar readings of about 70 volts engine running at about 4000 RPM.
I would also consider removing the alarm altogether if it is temperamental. You don't really need it on a '00 machine. It is just another gadget to drain the battery.
Almost certainly a Reg/Rec. Why not take Jeffs off and try that? Just check the electrical plugs are the same before you take his off though, as your's may just have the early type.
What a splendid idea, and so obvious aswell!! I'll consult Haynes to work out where it is for a start then whip it off, cheers Pete x
#6 | |
An alarm will not 'drain' the battery. If the electrical system is faulty fix it - ridiculous to blame the alarm.
I have a suspect reg rec at the moment on one of my bikes.
I use one battery between two SVs, no point having two, can only ride one at a time. I started noticing that it got more difficult to start after a few nightshifts last year, I particularly took note at how the lights dipped when revved whilst idling. It was very significant. It refused to start one day as the battery was completely dead. I know its not the alarm as its never ever been an issue. I know its not the battery as it has been used on the other SV since, and hasn't died a death over winter, as after three months without even touching it, the bike started pretty much as it should do(with no petrol in the carbs it takes a little more persuasion. It drained on the one with the suspect reg rec As Pete says, if you have a mate who has a reg rec, borrow it, or take note of the meter readings off theirs. When I can be bothered I will be swapping mine over(2 SVs does have its uses ![]() Not that either bike is going anywhere anyway!
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
its that charging issue again :) | AndyBrad | SV Talk, Tuning & Tweaking | 22 | 12-10-09 03:24 PM |
Charging - AGAIN | Tris | SV Talk, Tuning & Tweaking | 7 | 15-04-08 04:15 PM |
Charging/Battery: | MrMessy | Bikes - Talk & Issues | 8 | 30-11-07 12:50 PM |
charging battery | hovis | SV Talk, Tuning & Tweaking | 6 | 24-09-06 02:59 PM |
Over charging | Tris | SV Talk, Tuning & Tweaking | 8 | 21-02-06 12:13 PM |
