Old 08-03-10, 04:49 PM   #1
Ricerocket
Default Curvy starting problems
When I start my bike in the morning from cold it runs fine for 3 or 4 seconds and then cuts out. If I rise the revs as i start it and hold them up for 10 seconds it runs fine. The bike has new plugs and is restricted.
Whats the cause of this?
Old 10-03-10, 09:00 AM   #2
Ricerocket
Default Re: Curvy starting problems
Anyone help me?
Old 10-03-10, 09:02 AM   #3
You using the choke?
Old 10-03-10, 09:14 AM   #4
Ricerocket
No, should I?
Old 10-03-10, 09:14 AM   #5
Yes, that's what it's there for.
Old 10-03-10, 09:16 AM   #6
Ricerocket
But It used to start with no choke, all the time?
Old 10-03-10, 09:19 AM   #7
You could try balance the carbs, sometimes that affects cold starting like that.
but the problem you describe is so common as to be virtually a characteristic of most bike engine... they start, then the speed reduces, then they cough and stop. Pop the choke on for 5 seconds and they run fine.
Old 10-03-10, 09:23 AM   #8
Ricerocket
Ok thanks mate I'll try that.
Old 10-03-10, 09:37 AM   #9
Shaun T
Mine does that when i don't put it on enough choke, do as yorkie says just use ur choke!!
Old 10-03-10, 09:58 AM   #10
Taipan
Taipan's Avatar
Mine does that with choke. Always starts and pops and dies, then sorts itself out and runs okay? But its always a couple of attempts to reach that stage. Never been happy about it doing that either.
starting problems redlavachips SV Talk, Tuning & Tweaking 9 08-02-10 06:40 PM
Curvy starting and Idling Problems gavinsky23 SV Talk, Tuning & Tweaking 13 12-10-08 08:55 PM
Curvy SV starting problems Bud SV Talk, Tuning & Tweaking 3 30-03-06 08:09 AM
Starting Problems! squirrel_hunter SV Talk, Tuning & Tweaking 20 07-12-05 12:08 AM
Problems starting riktherider SV Talk, Tuning & Tweaking 4 11-06-05 06:13 PM
