Old 08-03-10, 09:01 PM   #1
timwilky
timwilky's Avatar
Default lamp shade removal tool, where to source
Daughters bedroom. When I fitted it out a couple of years ago, the lamp fitting has 3 lamps, G9 type fittings and sodding small shades.
To secure the shades there is a screw ring, about 1" diameter with a serrated circumference and a special tool to remove shades to change bulbs.
Said tool is a bakelite type plastic and I think the daughter has tried before reporting two failed bulbs. The problem is the tool has cracked and expands/slips as you try to turn it.
Does anyone know where you can source such tools? before I have to admit defeat and go out an buy a new fitting.
Not Grumpy, opinionated.
Swingarm Removal Tool sprocket SV Talk, Tuning & Tweaking 20 04-03-12 12:50 PM
Rotor removal tool lazymanc Pennine Massive 3 13-06-09 10:47 AM
Flywheel removal tool yorkie_chris Stuff Wanted 9 19-04-08 12:17 PM
Engine removal tool sickboygti Stuff Wanted 8 30-09-07 06:49 AM
Tool Box Removal Pointy hoppy34 SV Talk, Tuning & Tweaking 11 14-09-07 06:11 AM
