Old 08-03-10, 09:25 PM   #1
chrisgt11
Default Curvy restrictor dimensions and fitting.
right i know theres alot of info on this but carnt find what i need to know.
ive fitted some washers that i had made up using dimensions off this site think it was 1mm thick, 44.23mm diameter and 18.41mm center hole but mine are 18.40mm will this be a problem?
also ive lifted the carbs off there rubbers and fitted the washers there is this right? as i expected a lip or something for them to sit on but there wasn't just a hole that got smaller to the cyclinder i think?
the bikes going to be dyno'd this week but just wanted to make sure everything sounded ok first and just to think the restriction is up july but the weather makes me want to get out on it
cheers for any info
Old 08-03-10, 10:02 PM   #2
Default Re: curvy restrictor
.1mm difference on the ID will make no noticeable difference IMO
There is almost certainly a lip inside the carb rubbers.
Old 08-03-10, 10:14 PM   #3
chrisgt11
ok maybe i missed that then but does it sound like its in the right place?
Old 08-03-10, 10:35 PM   #4
Default Re: Curvy restrictor dimensions and fitting.
Yup, in between the carbs and engine.
Old 09-03-10, 09:19 PM   #5
chrisgt11
cheers for the help yc
also i insured it today and went for a spin but still feels powerful but it is my first bike.
i also got it booked in next week for a dyno run to check its at 33bhp but the dimensions on here should be right so hoping for a sunny weekend
Old 09-03-10, 09:36 PM   #6
I wouldn't bother with a dyno unless your insurers want one TBH. Dynos overread.
Info: Dimensions of Curvy Restriction Washers RatchetJob SV Talk, Tuning & Tweaking 18 02-09-12 05:25 PM
standard curvy naked bar dimensions noob-saibot SV Talk, Tuning & Tweaking 0 23-02-09 06:02 PM
Fitting a 33bhp restrictor kit to a '00 curvy e5hughsonm SV Talk, Tuning & Tweaking 6 18-08-08 03:03 PM
Restrictor for Curvy SV Gazz For Sale - SV's and SV related items 4 14-08-08 12:11 AM
Lower Fariign Fitting Kit -What are the dimensions?! fenris SV Talk, Tuning & Tweaking 2 18-02-08 09:37 PM
