Mini-Twins Goto Minitwins Official Site
Old 08-03-10, 11:37 PM   #1
benjo1
Default Front fork help
I have been sold a lemon of a bike, trousers round the ancles job but can anyone help me with what i have on the front fork setup?
some images of whats there:
http://s3.photobucket.com/albums/y71/benjo4283/
if anyone can tell me what emulator type these are, if they are! i know they arent the usual racetech ones. even better would be to help me set them up.
i have initially tried 20wt but they were too stiff to compress atall, so i went to 10 wt but its still a bit syrup ish on the damping.
in the top of the actual damper rod i am 1.5 turns out from fully in on the screw in the top(not seen in pics) and have the top preload adjuster screwed on as far as posible onto the damper rod.
I know the feel of good 400 forks and these feel poo. any ideas would be appreciated.
cheers
Ben
Old 09-03-10, 11:59 AM   #2
SV650Racer
Default Re: Front fork help
Cant see pics as its asking for a log in.
Old 09-03-10, 12:32 PM   #3
benjo1
Old 09-03-10, 12:33 PM   #4
benjo1
Old 09-03-10, 12:37 PM   #5
benjo1
pics shown are in the order they came apart, sorry about the image quality.
Fluid height is 130mm from the top, measured after pumping damper rod and leaving in the down position.
Old 09-03-10, 01:13 PM   #6
fastdruid
fastdruid's Avatar
Looks more like a cartridge than an emulator to me.
Druid
Old 09-03-10, 01:20 PM   #7
SV650Racer
Thats an R6 cartridge. You need 5w oil and 110mm air gap and the rebound screw adjuster 2 turns wound out from fully in.
Old 09-03-10, 05:28 PM   #8
benjo1
Cheers chaps, thanks alot. Am I running a big disadvantage on this kit?
could you suggest what i should have and where to get it, how much etc? SV650 racer sure can ahem!
Old 09-03-10, 05:36 PM   #9
SV650Racer
That kit isnt bad, it just over complicates a simple fork that can be made to work very well simply!. Id recommend setting it up properly and seeing how you get on with it. It wasnt a cheap mod either, more than likely done by Maxton.
Failing that we have always used a Racetec emmulator / ktech or ohlins fork spring setup with oil/airgap to suit the rider. That works very well. PM me if you want more info on that.
Old 09-03-10, 05:47 PM   #10
adjblade
See my add for emulators and springs in the SV parts for sale section
Front fork Oil Help Lucas66 Bikes - Talk & Issues 13 17-08-09 09:44 PM
Front fork problems touch107fm Bikes - Talk & Issues 3 26-10-08 03:41 PM
Sorry about another front fork conversion. sv_rider1990 SV Talk, Tuning & Tweaking 5 22-02-08 08:02 PM
Front Fork Setup Jester666 SV Talk, Tuning & Tweaking 7 14-08-06 03:12 PM
Front fork help? Bikerz SV Talk, Tuning & Tweaking 5 25-05-05 03:12 PM
