Old 09-03-10, 05:37 PM   #1
stu90
Default Restricted bike questions.
I have a k6 sv 650s and because of the law i needed the bike restriced. the bike gets to 7 grand of revs fine then it hesitates and stops pulling does any one else have this problem ? also i only get 126 miles to a full tank is this normal?
Old 09-03-10, 05:39 PM   #2
speedplay
Default Re: restrictors
126 miles to a tank's not too bad.
Your obviously not trying hard enough
Old 09-03-10, 05:40 PM   #3
TazDaz
That is how the restriction works, it cuts the revs down to 7k(ish), so nothing unusual there.
126miles to a tank seems a bit low to me, but depends on whether you are sat at 7k the whole time.
Old 09-03-10, 05:41 PM   #4
speedplay
I never used to get more than about the 125 miles to a tank mark out of my unrestricted pointy.
Old 09-03-10, 05:43 PM   #5
TazDaz
Hmmm....restricted I was getting 150ish. Full power around 135ish.
Old 09-03-10, 05:44 PM   #6
speedplay
You must have the diesel version then
Old 09-03-10, 06:48 PM   #7
Stu
Trinity
Stu's Avatar
sounds like you've got the inferior restricted by washers instead of restricted by ECU
Old 09-03-10, 06:54 PM   #8
stu90
yeah it is, it has a throttle stop and two washers in the air box
Old 09-03-10, 07:05 PM   #9
Mej
Default Re: Restricted bike questions.
i could never find the throttle stop on mine, i dont reckon it has one.
Old 09-03-10, 07:45 PM   #10
Dave20046
Dave20046's Avatar
Your fuel consumption's about the same as mine. On my restricted curvy I was getting like 90 miles if I was lucky. However, that said fuel consumption largely depends on how you ride it.
The pulling thing sounds normal enough, I usually hit about 7k get that annoying hesitation/suddenly pulled back feeling then it proceeds to pull a little bit more (not a lot). Doesn't stop dead though.
Is my bike restricted? barberpool SV Talk, Tuning & Tweaking 75 04-06-09 05:21 PM
How to tell if my bike is restricted? slloyd SV Talk, Tuning & Tweaking 22 25-03-09 10:35 PM
Which first big [restricted] bike? Rhiwbina_Squirrel Bikes - Talk & Issues 33 15-05-08 04:02 PM
Does a restricted bike need to be run in? Tiger 55 SV Talk, Tuning & Tweaking 6 19-11-07 10:40 AM
Some questions for people that got the SV restricted. 33bhp KayDee Bikes - Talk & Issues 5 03-09-05 01:39 AM
