Old 11-03-10, 12:37 AM   #1
ziva
Default Where to buy a replacement engine?
hey all my sv has died (the big end has gone) any one know where i can get a cheep second hand engen?
Old 11-03-10, 12:42 AM   #2
fastdruid
fastdruid's Avatar
Default Re: sv rebild
I'm presuming you're not English, telling us where you are from and which year SV may help?
Ebay, breakers or in the wanted section here is probably your best bet.
Druid
Old 11-03-10, 12:53 AM   #3
ziva
right sorry yea im not english but i am liveing surrey and the bike is an x reg so a 2000 modle
Old 11-03-10, 01:02 AM   #4
fastdruid
fastdruid's Avatar
Quickest way is probably from a breakers or Buy it Now from ebay but you'll pay more, auction off ebay would normally be cheaper but may take some time.
Put an 'ad' in the wanted section, you may be lucky.
FYI on this site 1999-2002 SV's are called 'curvy', 2003 onwards are called 'pointy', you can fit the 'pointy' engine into the curvy with swapping a few bits but getting a 'curvy' engine would be easiest.
Druid
Old 11-03-10, 01:06 AM   #5
ziva
right ok but can you tell me how i can change the engens of the 2003 modle into the "cervy" frame
Old 11-03-10, 09:41 AM   #6
fastdruid
fastdruid's Avatar
Default Re: Where to buy a replacement engine?
Not done it myself, you certainly need to blank off the 'pair' system, not sure if you need to replace/swap ign pickups / flywheel. Not really a lot to it.
Try the search.
Druid
Old 11-03-10, 09:42 AM   #7
Block PAIR ports
Swap alternator rotor
Swap side cover/alternator stator
Swap inlet rubbers
You might also have to block oil cooler ports depending what exhaust you use. Or get longer lines to move cooler.
Old 18-03-10, 11:18 PM   #8
ziva
its the big end thats gone and its gone BADLY
Old 19-03-10, 12:11 AM   #9
21QUEST
21QUEST's Avatar
I have one with 30K on it.
It'd need new front exhaust studs which I'm going to get and fit...fingers crossed the old ones come out okay hehe. Studs are damaged as had to cut the nuts off. Engine is actually still in the frame so will need some time to get it out.
I'm in Surrey so not a million miles away from you. I assumme you' are able collect? I don't drive so can't deliver myself but can get it delivered by a Courier.
If interested , PM us and we could possibly work something out.
Ben
Nemo me impune lacessit.
Old 25-03-10, 10:02 PM   #10
ziva
im intersted but how much you looking for it?
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Dead Sv Engine or Engine block.... Andy Jeffries Stuff Wanted 6 15-08-09 07:46 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
Reg/rec replacement Slim666 SV Talk, Tuning & Tweaking 9 16-02-08 06:55 PM
Reg/Rec Replacement K3 andywilson460 SV Talk, Tuning & Tweaking 6 10-10-07 08:26 PM
