Old 13-03-10, 08:37 PM   #1
madnlooney
madnlooney's Avatar
Default Rear brake pedal adjustment
so i have adjusted the pedal up abit as i found it too low, but now the brake light doesnt come on. ive tried looking for the adjustment switch as per
but cant find it. Is is below the pedal? or above where the pedal high adjustment screw is?
Riding round doing my thing
hello im Dan
madnlooney is offline   Reply With Quote
Old 13-03-10, 08:42 PM   #2
carternd
carternd's Avatar
Default Re: Rear brake pedal adjustment
It's hiding behind the plate by the side of the footpeg. Turn the nut, not the switch when you're adjusting it, or you will have problems.
carternd is offline   Reply With Quote
Old 14-03-10, 12:31 PM   #3
madnlooney
madnlooney's Avatar
thanks mate, will have another look now its light
hello im Dan
Old 14-03-10, 05:44 PM   #4
Holdup
Holdup's Avatar
What sv have you got?
I dont know about the curvey, but K3 the swtich is on the inside of the frame infront of the hanger as if your looking from behind (if that makes sense) and i belive K4 on it is on the heel plate
HUCA Club Member
Holdup is offline   Reply With Quote
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 10:00 AM
anyone got a Rear Brake Pedal tonyk Thames Valley 7 06-09-09 06:48 AM
99-02 rear brake pedal Marcus Stuff Wanted 17 14-04-09 07:27 PM
Rear Brake Pedal teknovision2 Stuff Wanted 1 24-07-06 06:21 PM
Rear Brake Adjustment andyaikido SV Talk, Tuning & Tweaking 6 23-06-06 05:33 PM
Powered by vBulletin® - Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
