Huzzah! My dad has fitted a new clutch - plates and srpings, and removed the slight small notches on the basket. He hasnt put the covers back on yet so I had a good inspection. When the lever is pulled, the plates dont have to move too much to be fully disengaged do they? I also see now how the plates are designed to interact with the hub / basket to transfer drive from the engine to the gearbox. Interesting stuff and some new things learnt
I cant wait to be back out on it, but with all this nice weather we're having now...tha can only mean it'll run out soon and rain will be here again ![]() Chain has been left soaking in my old engine oil aswell, I've had a nightmare trying to keep it rust-free...the rollers have been fine, but the sideplates have taken a beating from the winter weather and the road salt ![]() by the way, where are the earths on the bike? I understand there is one somehwere on the engine or on the frame, I can't locate it though but I want to check the earths because I have a "christmas tree" effect when I have my indicators on! Roll on the biking season. Matt |
The Sick Man
right on the back of the engine, look behind and under the shock, you will see a single bolt with black cable attached, carefull, dont turn on bike with it disconnected, you may fry some other wiring (i did this once, there are multiple earths, but this one is the load bearing cable the others are too weak)
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
What TSM said plus the main earth for the extras / ECU etc is the little flat spade connector just off the battery 'earth' lead. Nothing works without that!
![]() Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 15-03-10 at 11:10 AM. Reason: smelling pistakes. |
So how you going to learn then? Pussy
#9 |
Clutch is easy to do too, good job to start learning on.
#10 |
Im doing a gearbox change on the R6 soon, shouldnt take too long hopefully. That is if i can get my ass in gear.
clutch | oussaiden | SV Talk, Tuning & Tweaking | 0 | 27-09-08 06:25 PM |
clutch set up ?? | leemole | SV Talk, Tuning & Tweaking | 4 | 10-02-08 12:51 PM |
Clutch Problem? Cutting off when releasing clutch in first gear! | puthsardarade | SV Talk, Tuning & Tweaking | 15 | 09-01-08 09:42 PM |
hey new clutch advice Kyoto Clutch | srxaus | SV Talk, Tuning & Tweaking | 3 | 14-08-07 04:25 PM |
Clear clutch covers to see the clutch spin while running. | TLRMAN | SV Talk, Tuning & Tweaking | 13 | 01-11-04 02:18 PM |
