Old 15-03-10, 09:58 PM   #1
svrich
Default Brake discs, which ones?
My left disc is working loose between the two sections i.e. the braking surface is loose, so I need to replace it. There are obviously a few options but mainly these ones;
1. buy a good secondhand one (good cheep option)
2. Replace them both with some of these, but which ones?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
I need to do it soon though
Any thoughts gratefully accepted.
Old 15-03-10, 10:40 PM   #2
Default Re: Brake discs, which ones?
How much rattle? Little bit isn't worth worrying about IMO
Old 15-03-10, 10:54 PM   #3
svrich
Quite a lot now. There is quite a bit of sideways movement. It looks like the circlip type bit on the bobbins on the back of the disc have worn, and a couple are missing. The right one is fine though.
Old 16-03-10, 06:45 PM   #4
steveg
steveg's Avatar
Just had the same problem with my k5 after 48k had about 3mm side to side movement on discs
bought 2nd hand set from org as new prices scared me
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 11-04-10, 08:18 PM   #5
mostin
I am also having problem with my front disc movement . the right front disc can be turned slightly , looks like wear in the rivets. have seen discs made by KAGIZUME . Anyone fitted these . Are they any good ?
Old 11-04-10, 09:29 PM   #6
beabert
Aren't floating discs supposed to move side to side? Mine do and just passed an mot.
Old 12-04-10, 07:24 PM   #7
mostin
movement is not side to side on mine, disc can be turned slightly on hub.
Old 12-04-10, 07:44 PM   #8
beabert
strange
Old 12-04-10, 08:05 PM   #9
Aidan
As mine get advisories at the MOT I decided I wanted to keep the quality of OEM (if anything Suzuki can be quality), but didn't want to spend the money, so bought some second hand ones with nearly full thickness. They're now waiting for the bike to fail its MOT and then I'll swap (motorway commute Reading to Newcastle means the pads will now outlast the bike)
Sadly, but usefully, bikers seem to trash their own bike in order to supply us with cheap spares!
Brake Discs LUMPY SV Talk, Tuning & Tweaking 25 19-01-08 04:49 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
brake discs antony SV Talk, Tuning & Tweaking 9 07-04-06 11:30 PM
New brake discs? CamScooby2 SV Talk, Tuning & Tweaking 9 14-06-05 08:53 AM
