Old 17-03-10, 01:35 PM   #1
M65
Default Need Some PC Help
Took the side off my case last night to look how many system fans I could have in the case. Also, while I was there I thought I'd try to tidy up the wiring. Didnt get very far though as it was already about the best I could make it. Only unplugged an IDE cable and a SATA cable. The SATA cable also has power to it from the power button on the case which connects to the PSU.
Anyway, after I put it all back together, the damn thing wont start up! I get a small "fizz" when I connect the power cable to the PSU like you normally get. When I press the power button, the LCD display on my case lights up for a fraction of a second then goes off. If I press the power button again, nothing happens. If I unplug it and plug it back in, I get the same split second lighting of the LCD display.
I took the PSU to work today and tried it on another PC and it worked fine. Bit gutted really cos I thought it might just ne a dud PSU. Now Im thinking it could be more serious. Oh, and I tried another power lead too and that also didnt work.
Any ideas anyone?
Old 17-03-10, 01:38 PM   #2
suzsv650
Default Re: Need Some PC Help
have you knocked some of the connections from the power on switch to the motherboard?
Old 17-03-10, 01:43 PM   #3
M65
Gave them all a good check last night and all connections seem fine to me.
Old 17-03-10, 01:48 PM   #4
Warthog
Sounds like something is shorting or tripping somewhere? You could try the diagnostic approach or starting it with a variety of things unplugged like extranous hard drives etc etc. In fact, just a PSU and mobo should start the fans etc running until it can't find a boot drive.
Old 17-03-10, 01:56 PM   #5
M65
Think thats going to be the plan for tonight. Pretty sure my motherboard is fried though
Old 17-03-10, 02:34 PM   #6
Warthog
I know the worrying feeling. I have a few spares if you are interested, ASUS A8N SE if I remember correctly.
Old 17-03-10, 02:38 PM   #7
fizzwheel
fizzwheel's Avatar
Well personally I'd try plugging the cables back in that you removed last night and see if that sorts it. ( Unless you've done that already )
Failing that as mentioned above. Unplug everything from the MB except the PSU and then see if it fires up. If it does, plug things back in one at a time until you find the culprit.
I've had similar before when a hard disk has blown and it shorts out and then the PSU trips and wont power on.
Failing that are all the MB mounts insulted its not something shorting out on the underside of the main board ?
Old 17-03-10, 03:31 PM   #8
Viney
Thats whats in my PC that is
Old 17-03-10, 04:15 PM   #9
beabert
what fizwheel said
Old 18-03-10, 07:59 AM   #10
M65
Well, got late last night before I could start to look at this but managed to get everything stripped right down to individual components. Got the board out of the case and got the front panel of the case (my case is rubbish and it was a right faff with all the wires and hidden screws!)
Anyway, got the on/off button wired back to the board and fitted the PSU. Pressed the power button and CPU fan span like a good un! Hopefully that means my board and CPU are safe and I just need to put it all back together. I'll be doing that tonight hopefully, if not tomorrow.
