I need a new thingy bob!
At the bottom end of the clutch cable, down near your boots, there is a metal 'thing' that grips the end of the clutch cable, so when you pull the clutch in, it moves the spring. Mine has almost rusted in two(!) and I need a new one, but as you can see, I've NO idea what it is. Anyone got the technical name for it? |
i think what you are referring to is riveted to the clutch lifter assembly (see part 17 in this diagram http://www.alpha-sports.com/suzuki_p...FQpgMAodNj8QKg ). if so then it only comes as part of the clutch lifter assembly. you could try fabricating something and riveting it on, but otherwise you'd have to replace the assembly
Is it the ' catapult ' shaped bit that bolts on & the spring also attaches to? A French site has it @ about 7 Euros ( + taxes + plus postage )
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#4 | |
http://fiche.ronayers.com/Index.cfm/...3/Group/CLUTCH Is number 17 what your after? |
check this if not stick a pick up and ill get you part no. and price what size sv and year
http://fiche.ronayers.com/Index.cfm/...9/Group/CLUTCH_ |
think its 17 , 18 , 19 ,
prices- ![]() ![]() ![]() ![]() ![]() ![]() Suzuki Mail Order 01227 454366 | Suzuki Counter 01227 378420 | Harley-Davidson Counter 01227 378410 Online Shop
Actions Check your basket Here is your current basket. Click on the product title to change your ordering details. If you want to remove any items, clear the 'Keep' box and click on 'UPDATE BASKET'. Keep? Description Price No. Total 23121-44100: CLUTCH RELEASE ROD £11.28 1 £11.28 23200-11D00: CLUTCH RELEASE SCREW £32.12 1 £32.12 09134-06010: SCREW £2.07 1 £2.07 ![]() ![]() ![]() ![]() ![]() ![]() The delivery cost for your basket is based on UK charges. Other charges may apply outside the UK, the full cost can be evaluated if you register or login.To buy these items, you need an account on the web site. If you have an account, then please login. If you don't have an account on the Robinsons Foundry web site, click: If you have an account on the site, enter your login name: and your password: now press If you've forgotten your password, enter your login name into the top box above, and press: Robinsons Foundry Ltd. Broad Oak Road Canterbury Kent CT2 7QG Phone: 01227 454366 | Fax: 01227 454726 | Contact Us Designed and hosted by Canterbury Web Services Limited © 2005-2007 Last edited by sz1; 17-03-10 at 08:30 PM. |
![]() ![]() is it this bit ? |
you would have to ring and check but if you buy 17 you might get 18 and 19 with it or you can get 18 and 19 as separates
#9 |
No, I don't think so, as judging by the OP's description, I think he's after the square-boxed-shaped-thinga-mi-jig that the clutch cable end is slipped into, which is riveted to another metal plate thinga-mi-jig that has the spring attached to it.
HTH Chin |
#10 | |
it's not listed as a sparete part so must come with 17. |
Clutch lifter assy. | yorkie_chris | Stuff Wanted | 7 | 17-10-09 05:16 PM |
clutch lifter assembly | mjc | Stuff Wanted | 0 | 01-06-09 05:46 PM |
Clutch lifter problem. | swinging_simian | SV Talk, Tuning & Tweaking | 6 | 29-05-09 02:18 PM |
clutch cover outer O'ring part no. 11484-19F01 | Duke | For Sale - SV's and SV related items | 6 | 25-03-07 04:23 PM |
MoFo's spirit lifter | _Stretchie_ | South & West Surfers | 20 | 24-07-06 07:11 AM |
