Old 25-03-10, 01:39 PM   #1
barwel1992
Default Running lean ?
just wondering without the air snorkel and 16mm tank risers with a slip on can with no baffle and velocity stack would my bike run lean ? (standard air filter)
Old 25-03-10, 03:33 PM   #2
barwel1992
Default Re: Running lean ?
any one ?
Old 25-03-10, 05:38 PM   #3
barwel1992
ok so looking to get a sv1000 snorkel now because looking at the gap with tank raised its going to get filled with crap been on a naked as well
Old 25-03-10, 05:46 PM   #4
Sosha
I'd just keep the snorkel you've got TBH.
edit: & Possibly
Old 25-03-10, 05:51 PM   #5
barwel1992
well im sort of coming to that conclusion, just dont rely trust the US lot lol they all say its fine and all that but some people (mostly uk) say that it make the bike run lean and run hotter
Old 26-03-10, 02:04 PM   #6
skyline
If you do go for it I would say get the bike to a dyno run afterwards to check the air/fuel mixture and go from there...
Old 26-03-10, 04:40 PM   #7
barwel1992
i dont think the 1bhp (if that) is worth me spending £25 for a dyno run to see if its making the bike run lean
lol
Old 26-03-10, 05:01 PM   #8
smoky
well, if you are not running rich now, then adding more air and keeping the fuel the same will make it lean... it's the unbaffled pipe that will make the biggest difference, not so much the tank raise. mine (carby) would hardly run with race yosh and stock carbs...
going to dyno is a good suggestion, not for the 1hp, but so that you are not running lean... you're spending a lot more on the pipe, if you can actually get dyno tuning for £25, i say DO IT!
Old 26-03-10, 05:09 PM   #9
rowdy
rowdy's Avatar
lol
As said above, dyno will benifit you from not running too lean = too hot = stress on engine, not the 1bhp increase.
Old 26-03-10, 05:21 PM   #10
i'd go down the dyno route too.
On her <<<<< is a desnorkeled air filter and a can with no baffle option. For this to run correctly a dyno was performed and the main jets drilled out to correct sizing. If anything she runs a hairs on the rich side IIRC. Never lean.
Yes its a curvy, pointies are slightly different...but all the same if you are messing about with stuff similar, you need to know you have done it properly.
I just have to remember I can't run her with a full air filter now.
Running lean / rich sauluk SV Talk, Tuning & Tweaking 10 15-05-09 02:06 PM
Running lean - apparently Messie Bikes - Talk & Issues 17 10-06-08 12:55 PM
How will I know if I'm running Lean? ClemsonSV SV Talk, Tuning & Tweaking 2 13-07-07 04:33 PM
Running Lean? Frank O SV Talk, Tuning & Tweaking 2 14-04-06 07:38 AM
Is my SV650 running lean? trailer_parks SV Talk, Tuning & Tweaking 5 22-11-04 01:53 PM
