Old 28-03-10, 04:45 PM   #1
SUPERSTARDJ01
Default Brake drag after new pads.
Hi,
just changed my pads on my zx6 b1 and now it's really hard to push not impossible though, the calipers were not seized before, is it just the pads need bedding in?
Old 28-03-10, 04:49 PM   #2
beabert
Default Re: Just changed my brake pads and now......
i think its because the pads are thicker so the unclean part of the pistons are now rubing on the rings, maybe try clean them.
Old 28-03-10, 04:58 PM   #3
SUPERSTARDJ01
I gave them a really good clean and grease before I put the pads in.
Old 28-03-10, 05:03 PM   #4
Biker Biggles
Biker Biggles's Avatar
Did you take the lid off the master cylinder and check the fluid level didnt get too high?Too much fluid can mean the pads dont retract enough.
Old 28-03-10, 05:18 PM   #5
+1
Old 28-03-10, 05:25 PM   #6
SUPERSTARDJ01
I might be being stupid but what do u mean? I took pads out gave the calipers a good clean pumped out pistons a bit and greased, undid nipple pushed pistons in placed in pads and holding pins, placed on disc secured and topped up fluid.
Old 28-03-10, 05:31 PM   #7
speedplay
Did you pump the brakes with no pads in?
Old 28-03-10, 05:36 PM   #8
SUPERSTARDJ01
Yes only enough to expose a little bit of clean metal to clean and grease.
Old 28-03-10, 05:48 PM   #9
SUPERSTARDJ01
Ah I get you now and no the brake fluid is just under the full mark.
Old 28-03-10, 07:35 PM   #10
gfewster
Try syringing a little out to get it down to halfway between min and max. May help, may not. Otherwise just keep bedding them in.
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Which brake pads? Nicky S SV Talk, Tuning & Tweaking 31 28-02-10 11:13 PM
EBC HH brake pads rob13 SV Talk, Tuning & Tweaking 9 30-11-07 03:30 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
Which brake pads??? GG HH????? ourkezx SV Talk, Tuning & Tweaking 1 19-07-06 08:47 PM
