Old 01-04-10, 11:40 PM   #1
mceachern_13
Default clutch engagement/adjustment after new chain & sprockets.
Just replaced my chain and spockets, put everything back together and for some reason the clutch wont engage now. Clutch push rod is still good, I know the solution is simple but I cant come to think of it!
Any ideas?
Thanks in advance.
Mceachern_13
Old 01-04-10, 11:57 PM   #2
Default Re: clutch engagement
Removing the lifter has somehow disturbed its adjustment or, if it was disassembled, it's not been put back right.
Firts make sure it's gone back together right - if it did come apart, then adjust the clutch like this:
Originally Posted by Me, Once Or Twice.
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Old 02-04-10, 12:34 AM   #3
Spikenipple
Spikenipple's Avatar
Default Re: clutch engagement/adjustment after new chain & sprockets.
Sid Squid's is absolutely spot on
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 05-04-10, 02:05 AM   #4
mceachern_13
Thanks so much guys, I can now ride, I knew it was simple,
Thanks again.
Which chain adjustment marker (new chain) rockster SV Talk, Tuning & Tweaking 14 22-11-09 02:12 PM
Clutch adjustment -Ralph- SV Talk, Tuning & Tweaking 16 29-05-09 11:48 AM
Clutch adjustment Dave20046 SV Talk, Tuning & Tweaking 13 22-09-08 03:41 PM
clutch adjustment mlrz4 SV Talk, Tuning & Tweaking 0 09-07-07 11:18 PM
Clutch adjustment question?? Jools SV Talk, Tuning & Tweaking 4 07-09-06 11:51 PM
