Old 06-04-10, 06:50 PM   #1
ThEGr33k
Default Datatool System 4 won't disarm.
My Datatool System 4 Red seems so have broken.
The symptoms are:
- Indicators no longer flash (normally would be 2 frashes = armed 1 = unarmed)
- Wont unarm at all. Only way I can is to turn the ignition on and off which sets alarm off, then press fob and it will be unarmed.
- Randomly goes off.
I think its still in warrenty so will see what the crack is with that... Just thought id mention it on here and see if anyone else has a clue what the crack is.
Old 06-04-10, 06:53 PM   #2
Default Re: Damn alarm (Datatool System 4 Red) seems to have gone south, anyone with experience?
mine did that once but righted its self, try disconnecting the battery and reconnecting.
Old 06-04-10, 06:53 PM   #3
rotax81
rip the danm thing out and bin it.
you can guarantee it will eventually completely pack in and you will be miles from nowhere. sods law.
takes me about 20 mins to rip one out from start to finish and get the bike back to 'normal'
Old 06-04-10, 06:54 PM   #4
if someone can take my fooooker off they can have it!
Old 06-04-10, 06:54 PM   #5
Dave20046
Dave20046's Avatar
The symptoms are:
Mine does that after it's been stood, seemed ok after I'd charged the battery.
Old 06-04-10, 07:18 PM   #6
skidmarx
It's a Datatool, you can expect a lot more of this type of thing. I'm not sure how many alarm systems are out there, 5/6 probably, but it seems to me that there are more 'HELP' posts here about datatool than any other. In fact I can't remember any other systems being posted about before. Datatool however seem to be a persitent problem. I've had one....never again. Bin it asap you will save yourself a lot of trouble in the long run imo. Good luck.....
Old 06-04-10, 07:19 PM   #7
ThEGr33k
Thanks for the replies
Well I have found a problem but not the cause. The fuse had blown. I replaced it and as soon as I turned the alarm off (which it did but dont again now ->) it blew again.
The only thing I can remotly imagine it being is the indicators that I just put on allowing too much flow. What dont make sense is that they are pretty much the same indicators that were already on... yes that sounds strange but one had blown and the bulbs weld themselves in (they are cheap after markets).
SOOOOOO my new question, what can cause the fuse to go "pop"?
Old 06-04-10, 07:23 PM   #8
Holdup
You havent got your indicators activated have you?
Like left in the turn left or right position, seems silly but that can cause problems, such as my system 3 flashes the sidelights as i havent got a diode in the circuit
Old 06-04-10, 07:27 PM   #9
skidmarx
You do realise this will be the start of a whole series of questions don't you It pains me to see another go through the datatool quagmire!
Old 06-04-10, 10:19 PM   #10
ThEGr33k
Sigh. There aint a great deal I can do. Its not as easy to take out as some of the earlier systems... Ill see what I can find.
First thing to check is with new fuse and no indicators (or at least not the new ones) and see where it goes from there...
Datatool System 4 Red TSM Bikes - Talk & Issues 47 23-09-21 06:20 AM
Datatool system 3 PIN? nobby SV Talk, Tuning & Tweaking 15 23-03-09 10:17 PM
datatool system 3 evertheoptimist SV Talk, Tuning & Tweaking 17 02-06-08 10:05 PM
Datatool system 3 suzsv650 Bikes - Talk & Issues 1 04-07-07 01:26 PM
Datatool System 3 TSM SV Talk, Tuning & Tweaking 1 16-07-05 11:48 AM
