My clutch was feeling a bit heavy, so decided to strip down the cable and worm drive, (worm drive was new last year) and give them a lube. As well as the heavy clutch, it wasn’t changing gear nicely, mainly on down shifts, I knew the chain was adjusted ok, and the oil level was good, although after reading a couple of threads on fully synthetic oil( using HG fully syn)that is in the back of my mind.
Cable and worm freshly lubed and adjusted, feels nice again. Now the gear change, straight away I noticed the front sprocket nut was loose, and being held on by the tab washer, there seems to be a few posts on the org of this happening. So the first problem I have is that the torque setting for this in the Haynes manual is 145Nm, which using the conversion factor of 1 pound = .225Nm , is just under 33lb, is this enough, bearing in mind how much grief it is (usually)to get off. Next I thought I’d give the gear lever a lube. Disconnected the linkage and removed the assembly from the bike. After a good soaking in freeing agent and lube, stills feels stiff. It will turn if you hold onto the foot peg and give it a bit of muscle, but it certainly isn’t free spinning. Also I can’t separate the lever from the foot peg assembly, seems to be on there to stay. How freely should it spin? Thanks,Mike |
[QUOTE=shelleyamy;2236289]
" fully synthetic oil( using HG fully syn) "Think the main problem here is clutch slip ( & expense ) " front sprocket nut was loose, and being held on by the tab washer, torque setting for this in the Haynes manual is 145Nm, which using the conversion factor of 1 pound = .225Nm , is just under 33lb, " Sums wrong - divide by 0.225 to give lbs/metre + 644.4 which is tight as R.Soles! " Next I thought I’d give the gear lever a lube. How freely should it spin? " Fairly free - has been a thread on this recently
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#3 | |
[QUOTE=punyXpress;2236310]
i knew it couldn't be right, stood on a 3ft breaker bar with a 2ft extension bar,hope thats enough. Thanks i'll try an find it. Mike |
#4 | |
A very old post indeed:
Good morning all.
Anorak man time! ![]() One nm is 73.8% of 1 ftlb, so 145nm= 107.01 ftlb. On occasion, the bush inside the gearlever becomes tight due to the lever corroding behind the bush & forcing it onto the footrest. You may have to remove the bolt holding the footrest to the hanger & get the lever off. These can be a dreadful pain, a good vice to hold the footrest is essential. Once removed, sometimes one can rub the bush down slightly, but often they end up falling to bits ![]() Cheers. |
You can just install it without the bush if desperate, it still works fine.
Tried heat, a can of plus gas, and a big hammer and it only moved about 5mm.It has freed up a bit and now spins a lot easier, but still not perfect. Wil work on it a bit more today. Mike
Bigger hammer
#9 | ||
the conversion works out at 106.946511605 lb Quote:
#10 |
Ah wind another bolt in there and hit the bolt, that will avoid peening those over. tickle it on the grinder to get rid of the raised bits
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) | martin_SV | SV Talk, Tuning & Tweaking | 10 | 30-07-08 08:40 PM |
K6 light blue/silver front fairing,indi's,gear lever. | Baz M | Stuff Wanted | 4 | 18-05-07 07:10 PM |
Gear lever & front indy | Cookie | Stuff Wanted | 0 | 17-04-07 03:14 PM |
Stiff Gear Lever | fizzwheel | SV Talk, Tuning & Tweaking | 2 | 09-09-06 02:42 PM |
Clutch lever is very stiff | The Mass | SV Talk, Tuning & Tweaking | 2 | 08-06-06 12:48 PM |
