Old 07-04-10, 03:59 PM   #1
SVFreak
Default Screen replacement on K3
Planning on purchasing an iridium screen for my K3.
Is it just a case of removing the five bolts that hold the screen in ? And mirrors.
Or will i need to remove any of the trim around the clocks ?
Also when i undo the five bolts will anything fall off the back off them (i:e nuts etc) ?
Old 07-04-10, 06:08 PM   #2
rowdy
rowdy's Avatar
Default Re: Screen replacement on K3
No need to remove mirrors, but you will probably have to remove the clock surround panel, it's only held in by a couple of screws. There are some little rubber grommets that are between the fairing panel and screen that the screen bolts go through, be careful they will probably drop out.
What screen are you getting?
I bought an airblade screen and had to trim some of the plastic on the clock surround panel where the top screws holds the screen in place for the clock surround panel to fit flush against the screen/fairing.
Double Bubble Screen OR Normal Tinted Screen For '08 (K8) cbay Stuff Wanted 3 02-02-10 12:23 PM
Looking for replacement screws for SV650S pointy screen JohnMcL7 SV Talk, Tuning & Tweaking 10 22-08-09 02:22 PM
DB Screen... or Sport Touring Screen? opinions plz :) Paul the 6th Bikes - Talk & Issues 21 07-04-09 08:15 PM
Replacement Screen Monkey6879 SV Talk, Tuning & Tweaking 9 16-01-07 11:53 AM
My SV replacement Saint Matt Idle Banter 30 07-11-06 01:54 PM
