Old 07-04-10, 07:25 PM   #1
bigoverdraught
Default starter clutch replacement.
Hi all, the bush in my starter clutch is well clutched, tried to get one from dealer and was told it is only available as a complete assembly £180, does anybody know different. thanks. Mark.
Old 07-04-10, 07:39 PM   #2
Default Re: starter clutch
I think just about all the starter clutches I've ever seen come as an assembly.
I'd be off to the breakers, any popped motor should donate the necessary bits.
Old 07-04-10, 07:41 PM   #3
+1 to Sid
These don't usually go wrong so plenty of spares about.
Strange actually, any pics of the damage and what symptoms were there of a problem?
Old 07-04-10, 10:18 PM   #4
bigoverdraught
Default Re: starter clutch replacement.
Thanks for your replys, i am building a spare engine from two damaged engines, one did not have a generator etc. on it, the other did, but the damage to the bush was probably caused when the end of the crank fell off, i found it all lying in the casing when i removed it.Better sharpen the penknife and get whittling.
starter clutch koby650 Stuff Wanted 0 10-04-08 03:10 PM
Clutch Cable replacement. dmracing SV Talk, Tuning & Tweaking 1 21-10-07 11:45 AM
Grrrr Starter Clutch TSM SV Talk, Tuning & Tweaking 3 13-10-07 10:54 PM
Starter Rotor Clutch I'm_a_Newbie SV Talk, Tuning & Tweaking 9 02-09-07 08:38 PM
Starter clutch repair info ktm155 SV Talk, Tuning & Tweaking 2 20-03-06 09:10 PM
