Old 08-04-10, 09:07 PM   #1
ty_uk
Default SV650 Hugger - no fittings, what's needed?
Hi,
Got the chance to buy 2nd hand hugger but does not come with any fixings..my Q is what are the required fixings?
Old 08-04-10, 09:12 PM   #2
rowdy
rowdy's Avatar
Default Re: SV650 Hugger
From what I can remember my hugger didn't either, you just use the chain guard fixings.
Old 08-04-10, 09:12 PM   #3
svrich
Probably depends upon the make entirely. What are you fitting it to, and are you able to find out the brand? My Puig on my Curvy used the original chain guard screws but had a special bracket to fit around the rear brake line on the right side.
Old 08-04-10, 09:20 PM   #4
ty_uk
suzuki sv650n/s '05 - '08 powerbronze carbon hugger
Old 12-04-10, 11:46 AM   #5
Default Re: SV650 Hugger - no fittings, what's needed?
You should be able to use the std fixings (for chain guard etc...), but u may need to buy a longer bolt for the brake hose mount. It should cost about £1 for a couple of stainless bolts.
Old 12-04-10, 12:09 PM   #6
ty_uk
Cheers m8
Old 12-04-10, 12:19 PM   #7
Also, double and triple to check it ain't rubbing anywhere on your tyre.
Can remember a few times we swore blind mine was fine, and it kept rubbing. Ended up jacking the brake mount side with washers to stop it!
Old 12-04-10, 01:24 PM   #8
ty_uk
Cheers Dizzy, Will do
Old 12-04-10, 04:11 PM   #9
rowdy
rowdy's Avatar
Mine did this and also vibrated the brake hose clip lose and scratched the swingarm up.
I cut a piece of rubber car matt and placed it between the hugger and swingarm to allow clearance and to cushion the vibration to stop the bolt becoming lose again.
Old 12-04-10, 04:51 PM   #10
To use standard shoulder bolts on my redfox one i had to put washers behind to take up the thickness difference.
Hugger for SV650 SK8 RedMacgregor SV Talk, Tuning & Tweaking 6 26-08-09 06:01 PM
52 sv650 hugger ging6996 Stuff Wanted 0 19-05-08 07:13 PM
Hugger fittings 5v5 rider SV Talk, Tuning & Tweaking 6 24-11-07 08:49 PM
Hugger, Belly Pan, Tail Tidy. Advice needed nomad SV Talk, Tuning & Tweaking 16 27-09-07 01:57 PM
Fitting a rear hugger advice needed! krhall Bikes - Talk & Issues 21 20-05-07 10:18 AM
