Old 10-04-10, 11:30 AM   #1
mikebrooman
Default Brake Fluid Everywhere!
Just got the bike serviced and woke up this morning to find brake fluid all over the rear tire, brake disk, side panel etc.
What is the best way to clean this off?!
Should I go and complain to the garage as they clearly overfilled it.
I also think they cracked my Revometer screen.
Old 10-04-10, 11:32 AM   #2
Scoobs
Default Re: Brake Fluid Everywhere!
Get it off quick with copious amounts of water and soap. It might already be too late. It will take all the paint off.
Old 10-04-10, 11:35 AM   #3
mikebrooman
Carp!
any idea where I stand with the garage? spend over £400 on service and full brake rebuild, but is it my job to check fluid levels?
Old 10-04-10, 11:44 AM   #4
It shouldn't be. It's possible they just shoved the pistons back to get new pads in.
Old 10-04-10, 12:11 PM   #5
blutonium92
f00k, bad luck. If i was you id march straight down the garage tell em and say you want it repaired if theres any decolouration or paint stripped.
If they dont pay for EVERYTHING then just report them to trading standards.
Old 10-04-10, 12:17 PM   #6
This is very probably what happened.
Old 10-04-10, 12:52 PM   #7
Which to me is a very funny idea of a full brake rebuild
Old 10-04-10, 01:08 PM   #8
mikebrooman
rear caliper was seized together so they brought me a second hand one for 80 quid and fitted that. replaced pads front and rear, and seals front and rear.
guessing they just weren't careful!
Old 10-04-10, 04:26 PM   #9
husky03
80 quid for a second hand caliper is shocking should be about 40-50 max
Old 10-04-10, 05:35 PM   #10
RichT
Call Trading Standards...
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
What Brake Fluid... DoubleD SV Talk, Tuning & Tweaking 10 03-03-08 11:21 AM
Dot 5.1 brake fluid DanF SV Talk, Tuning & Tweaking 2 09-04-07 03:15 PM
Brake Fluid top up Nekkid SV Talk, Tuning & Tweaking 7 30-03-07 11:57 AM
Brake fluid Trix SV Talk, Tuning & Tweaking 14 20-01-05 11:13 AM
