Old 11-04-10, 04:11 AM   #1
Preston
Default 99-02 rear caliper alternative?
there any good rear calipers that can be changed for the stock ones with min moding
or is it changing the swing arm the only way? if so think an MV F4 750 " lets say of an 04 " would fit? would love a singal swing arm on an sv would look nice.
Old 11-04-10, 09:04 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: 99-02 caliper swaps
The rear caliper on the curvy SV is actually a really good caliper if it's clean and in good working order
2011 Speed Triple 1050
Old 23-04-10, 09:05 PM   #3
Preston
well would not say there good they stop ya but they ant good..
i wanted to know if anyone makes after market ones failing that ill have to get some 996 or 749 brembos and make some plates to fit em..
Old 23-04-10, 09:09 PM   #4
Holdup
Should try a pointy one then...
Old 23-04-10, 09:14 PM   #5
barwel1992
the problem is, if the back is to strong then all your going to do is lock the rear up
tried a braided line and HH sintered pads? given them a good clean and grease ? if not then id do that first
and yeh what holdup sead
Old 23-04-10, 09:26 PM   #6
999/749
fit that pin
change those spacers
resulting in
Old 24-04-10, 01:39 PM   #7
Alpinestarhero
Doubles my braking power!
I need to squeeze the front brake a bit more...
Old 24-04-10, 01:57 PM   #8
I don't think pads on that fancy duc caliper have touched disc on mine yet
Old 24-04-10, 07:31 PM   #9
Preston
point of the post was if there was an after market caliper that would bolt on to stock mounts but i see that there ant.
well you only lock up the back end if your A, a novice rider and dont know what ya doing or B you wanted to( but cant see any reason why you would ). you can lock the back end up easy with the crap sv calipers. BH lines are a given on any bike road or race.
Yeah i seen the convert plate from TWF, and the spacers but am not a fan, look abit out of place so am doing to get on the CNC and make somthing bit better... ill post some pics when am done.
Old 24-04-10, 07:41 PM   #10
barwel1992
Default Re: 99-02 rear caliper alternative?
if you can lock up the rear with the sv calliper then why would you need a better one ? better feel ? more controllable rear brake?
or is it just a bling thing ?
Alternative rear shock for a curvy? stew SV Talk, Tuning & Tweaking 15 10-04-10 09:10 PM
Alternative Sv rear brake reservoir maviczap SV Talk, Tuning & Tweaking 8 04-01-10 12:41 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
replacement rear brake pedal alternative husky03 SV Talk, Tuning & Tweaking 0 22-05-07 09:43 PM
