Old 16-04-10, 01:37 PM   #1
Maverick9999
Default Where should I be spraying ACF50 on my pointy K4?
Hi there,
Now that the sun has finally come out, I thought it's about time that I give it a good wash and polish. I was thinking of applying some ACF-50 to make sure it's protected against corrosion as I hear sv's get a little furry if exposed too long to the elements.
I haven't applied ACF-50 before and am wondering where the problematic areas are that should I be looking to apply it?
Any ideas?
Old 16-04-10, 01:41 PM   #2
Stig
Default Re: Where should I be spraying ACF50 on my pointy K4?
Anywhere you like so long as its not on the brakes or brake disks. Spray everything electrical and steel.
Old 16-04-10, 01:53 PM   #3
SUPERSTARDJ01
+1 or Tyres
Old 21-04-10, 10:17 PM   #4
dubno
After a good wash I normally spray it liberally (avoids the bit mentioned in earlier posts!) to the engine, suspension and frame. Let it soak for a bit whilst you polish the frame and bodywork with it. Run the engine or go for a short ride to heat up the engine - the heat will cause the liquid to burn off leaving a residue over the engine that will protect the bike for months at a time. The fumes off the hot engine also coat everything inaccessible plus it smells kinda good too.
I have used ACF50 for a few years and it works a charm! Bike is clean and corrosion free after 6 years heavy use. Well recommended!
Acf50? Richie Bikes - Talk & Issues 11 01-12-09 03:16 PM
ACF50 time steveg SV Talk, Tuning & Tweaking 20 29-11-09 12:47 PM
ACF50 On Chain? svdemon SV Talk, Tuning & Tweaking 6 10-11-08 12:52 PM
ACF50.,..where to put it? andyb SV Talk, Tuning & Tweaking 12 21-02-07 01:22 PM
acf50 question steveg SV Talk, Tuning & Tweaking 13 03-01-07 08:28 AM
