16-04-10, 05:42 PM | #1 |
Petrol cap smells of petrol?
Bit of a daft question i think but here goes. With my petrol cap closed and locked should i be able to smell petrol at said cap?
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
16-04-10, 05:46 PM | #2 |
Re: Petrol cap smells of petrol?
It better be normal just had a sniff and yes I could smell the faint woft of gasoline
16-04-10, 05:52 PM | #3 |
Cheers tommo, i know it sounds like an odd question but ive just spent the last few days re-building my carbs because of fuel leak and hydrolocked front cylinder and im paranoid about losing any more expensive fuel
16-04-10, 06:01 PM | #4 |
please dont take my word for it, with my luck your probably not meant to smell fuel...lol
16-04-10, 06:04 PM | #5 |
Well nee wonder im smiling for hours when ive been out for a ride, its all the leaking fuel vapours heh heh
16-04-10, 06:06 PM | #6 |
With a suitable bit of hose blow down the little hole next to the filler, if you can hear it in the tank the filler well drain pipe is rusted out.
Do a search, sadly it's happened to a few bikes.
16-04-10, 06:11 PM | #7 |
Cheers sid i will try that thanks for help
16-04-10, 06:16 PM | #8 |
so does that mean your not meant to smell anything...?
16-04-10, 09:25 PM | #9 |
Don't think the cap itself is air/fuel tight!
Lifted my tank on the prop & surprised to find fuel dribbling down it. ( tank was almost full ) On Sid Squid's suggestion: try putting some WD40 down it & see whether it comes out the bottom - if not, you've got problems, water will get into tank & speed the rusting process.
Was: K2 naked in rapid yellow - gone to a better? place Now: Street Triple R |
16-04-10, 10:35 PM | #10 |
Yes its normal
Ran out of petrol... | Iansv II | The Essex Lounge | 4 | 12-08-09 06:57 PM |
petrol tap | hovis | Bikes - Talk & Issues | 6 | 13-09-07 07:58 AM |
Old Petrol/Oil | Grinch | SV Talk, Tuning & Tweaking | 19 | 25-04-07 06:10 PM |
Petrol - Which One? | krhall | Bikes - Talk & Issues | 36 | 25-04-07 08:57 AM |
What Petrol? | Rodger Wabbit | Bikes - Talk & Issues | 40 | 15-10-04 05:50 PM |
