Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 19-04-10, 06:41 PM   #1
Tim in Belgium
Default Race Bike Cooling systems
With race bikes you have to run water instead of coolant, which is fine.
Two Questions:
1. Can you use any old water? Or does it need to be deionised/distilled type?
2. When not in use/between races is is best to drain it, leave it in or something else to minimse corrosion?
Old 19-04-10, 07:55 PM   #2
lukemillar
Default Re: Race Bike Cooling systems
I run water wetter, which is non-glycol based so safe for race bikes. Doesn't get to freezing point here over winter (plus I race over winter!) so I'm leaving mine in the bike.
And I used bog standard tap water to mix the water wetter.
Old 19-04-10, 08:02 PM   #3
Tim in Belgium
It's toasty warm in the garage so I presume that means leaving it in will be fine.
Old 24-04-10, 09:16 AM   #4
I'd pop some antifreeze in there when not using it just for the anticorrosion additives.
Old 24-04-10, 11:32 AM   #5
flymo
flymo's Avatar
I do the same, the day after the race season completes (or when I can be ar$ed to be truthful) pop a good mix of anti-freeze in there and then drain and replace at the start of the following season.
Old 27-04-10, 08:48 PM   #6
Tim in Belgium
Just flushed through with hose water and refilled with demin.
SV 03 race bike,or bike for race bike build jonniefla Stuff Wanted 2 02-01-09 11:47 PM
new bike exhaust systems kwak zzr Bikes - Talk & Issues 13 21-09-07 01:49 PM
sv650 k1 cooling fan bugsy46 SV Talk, Tuning & Tweaking 3 21-06-07 09:00 PM
Too much cooling help Bonart SV Talk, Tuning & Tweaking 7 29-12-05 09:15 PM
Cooling Fan Banus SV Talk, Tuning & Tweaking 7 10-06-05 09:05 PM
