Old 23-04-10, 08:39 AM   #1
kiggles
Default tank bolts not line up?
Hi everyone i have just recently got a spray job on my SV650. When putting it back together my tank bolts by the handle bars are about 3-4 mm out of line of the holes which they screw in. Has any one got any ideas which may solve my solution.
I have got a small idea what it might be. You know the rubber insert which goes on the other end of the tank where the pivot bolt holder is, i am unsure which way around this may go even though i have got it same way around as my other SV is doesn't line up.
Could someone comfirm me which way around the rubber insert goes whether the chucky side goes facing up or down. Or a solution to my problem
thanks for reading thread.
kev
Old 23-04-10, 08:21 PM   #2
svrich
Default Re: tank bolts not line up?
Have you tried loosening the hinge bolts? I put mine back on after a service and had the same problem. I loosened the hinge bolts slightly and lined up the top bolts before doing them all up at the same time.
HTH
what size tank bolts do i need k3 pointy barwel1992 SV Talk, Tuning & Tweaking 11 21-03-10 01:45 AM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
Blue Baglux tank cover and tank bag (for pointys) for sale! thor For Sale - SV's and SV related items 7 13-01-06 01:04 PM
Pick & mix (stainless) bolts on line chewy22 For Sale - SV's and SV related items 1 25-11-05 01:31 PM
Stainless Bolts & Tank Raisers graywok SV Talk, Tuning & Tweaking 37 23-09-04 09:23 AM
