Old 24-04-10, 01:27 PM   #1
mouse8197
Default which engine for 2000 curvy
hi guys,
was just wondering up to what year engine would i get in a 2000 curvy would it be a 2002 or would i get away with a 2003. im not sure when they changed from carbs to fuel injection.
thanx in advance mark
Old 24-04-10, 01:30 PM   #2
Alpinestarhero
Default Re: which engine for 2000 curvy
The carb'd models ran from 1999 to 2002; in 2003, suzuki changed to fuel injection. It is ppossible to get an injected engine in there, but the injection system requires some more space - you can raise the tank a little I beleive, but its a bit more involved work
Old 24-04-10, 01:33 PM   #3
ASH why the bleedinell would you fit EFI?
Any engine will fit.
99-02 fits directly.
03-06 engine, you need to change rotor, stator, intake rubbers and block PAIR ports and do something with oil cooler (either remove, move or fit different downpipe to clear it).. That lot allows you to fit the late engine in and use your existing carbs and ignition setup.
Stay away from 07> with twin plug heads.
Old 24-04-10, 01:36 PM   #4
mouse8197
cheers guys i thought they'd changed to fuel injection in 03 will stick to carbs will be an easier fix without havin to mess about
Old 24-04-10, 01:37 PM   #5
Alpinestarhero
Didn't say the OP had to. I suggest it is possible and I also state it is more work.
Some people like a challenge though It has been done before
Old 24-04-10, 01:38 PM   #6
Alpinestarhero
Most definatly, keep it simple and there'll be less mistakes
Old 24-04-10, 01:38 PM   #7
They did, didn't do anything useful though it was just for economy and makes it more complicated.
2000 Curvy sv_rory For Sale - SV's and SV related items 14 05-04-09 09:16 AM
2000 sv 650 engine nubi4life Stuff Wanted 2 27-08-08 03:16 PM
Engine stutter (after a good blast) - Curvey 2000 S Tony_BLY SV Talk, Tuning & Tweaking 20 27-09-06 03:36 PM
Engine from a 2000 model yorkshiregooner For Sale - SV's and SV related items 3 26-05-06 08:17 AM
Engine Replacment - 2000 SV650 SY jonkin2 SV Talk, Tuning & Tweaking 24 19-10-04 06:23 PM
