Old 27-04-10, 09:14 PM   #1
garynortheast
garynortheast's Avatar
Default Pre-load adjusters on curvy forks?
I've noticed a few pictures of curvy model SVs with pre-load adjusters on the forks. My curvy doesn't have any adjustment at all on it so I'm assuming that people are fitting these adjusters retrospectively. Am I right and if so what are they from?
Old 27-04-10, 09:15 PM   #2
husky03
Default Re: Pre-load adjusters on curvy forks?
kind of=they were fitted to late 02 curvys
Old 27-04-10, 09:23 PM   #3
garynortheast
Ah right, thanks for that Husky. I take it they should fit my 2000 curvy then?
Old 27-04-10, 09:30 PM   #4
husky03
yep
Old 27-04-10, 09:31 PM   #5
garynortheast
Cheers for the info.
Old 27-04-10, 09:36 PM   #6
Money better spent on the insides, not the out. When you have proper springs and sag set you won't touch them.
Old 27-04-10, 09:44 PM   #7
garynortheast
It was more in the nature of an idle enquiry really yc. Forks are not too bad on the whole, they seem to work ok for my 11½ stone. When I do finally pull them apart 9probably next winter) I'm likely to be putting a set of progressive springs in along with new oil, seals and bushes. I may well just top them off with a set of preload adjusters.
Old 27-04-10, 09:45 PM   #8
I would spend on those cheap emulators from states instead if you were determined to spend money. Also I would not replace seals and bushes unless they needed it.
Old 27-04-10, 09:49 PM   #9
garynortheast
The seals certainly will need doing by then if not before. They are already leaving a faint black ring of dirty oil around the top limit of the travel on the stanchions after a few days of riding so I suspect given the mileage I'm clocking up on the bike they are going to need doing sooner rather than much later. I'm inclined to give the forks a really good overhaul while I have them apart.
Old 27-04-10, 10:13 PM   #10
punyXpress
punyXpress's Avatar
Just put K-Tech springs in my Curvy @ 37000 miles. Seals & bushes were fine.
Wouldn't be surprised if most of the black line is road filth?
Now: Street Triple R
Pre-load adjusters Lucas Stuff Wanted 45 28-06-08 02:04 PM
Pre-Load Adjusters PaulyMac SV Talk, Tuning & Tweaking 4 06-12-06 10:44 AM
pre-load adjusters jayjay SV Talk, Tuning & Tweaking 2 17-04-06 03:05 PM
Pre-load adjusters on a 2000 model The Wolf SV Talk, Tuning & Tweaking 3 15-06-05 12:22 PM
FORK PRE-LOAD ADJUSTERS ON A 'NAKED' alexb SV Talk, Tuning & Tweaking 4 21-01-05 09:19 PM
