Old 28-04-10, 03:37 PM   #1
svshaz
Default Bike lowering and tyre fouling?
hi, i'm new to sv's but own a new pointy which i've had to get lowered. Problem is i've now found that the rear tyre catches on the underside of the rear fender and wondered if anyone else had similar issues when lowering thier bike. I'm about 54 kg and wouldnt of thought it would have been a problem so any help much appreciated.
Old 28-04-10, 04:30 PM   #2
Default Re: Bike lowering and tyre fouling?
Your weight isn't the overriding factor, if the suspension has had bits changed that allow the tyre to move far enough that it will hit something - it will hit something.
I strongly advise raising it back up a bit until nothing touches.
Old 28-04-10, 04:38 PM   #3
+1
Tiptoes/scooped out seat/platform shoes/whatever.
The suspension NEEDS to work properly, it is much more important than falling over at 0mph occasionally
Old 28-04-10, 04:54 PM   #4
hongman
I am going to be facing the same problem as you I think - just curious, how tall are you?
Old 28-04-10, 05:47 PM   #5
I would advise you buy a bike which handles good with a low seat, rather than try lower an SV to a dangerous level.
Old 28-04-10, 06:53 PM   #6
svshaz
thanks for the replys guys. I'm 5'2" and had the dogbones changed to lower the bike like a lot of other people seem to do but never heard of a problem like this before.
Old 28-04-10, 07:08 PM   #7
barwel1992
suspension knackered ?
never head about the tire hitting before
Old 28-04-10, 07:10 PM   #8
Suspension moves through an arc, knackered or not. Knackered suspension just does it without damping.
I've heard of it, and I say same thing in all these threads.
Old 28-04-10, 07:13 PM   #9
barwel1992
i was meaning more along the lines of the spring is knackered
how much have you had it lowered ?
Old 28-04-10, 07:44 PM   #10
svshaz
bikes been lowered about 40mm. Cant see it being the rear shock 'cos the bikes only done 600 miles and is new. I've measuered the dogbones and as far as i can tell its 165 mm between hole centres. If anyone can shed any light as to whether this is too much i would be v. grateful.
Ermax undertray fouling rear tyre Mr_Chin Bikes - Talk & Issues 10 28-08-09 04:39 PM
Another bike lowering thread.... Miles SV Talk, Tuning & Tweaking 3 15-07-08 08:48 AM
Heli Bars and screen fouling problem maviczap Ancillaries 0 30-03-08 06:22 PM
Intro and question regarding bike lowering delpel SV Talk, Tuning & Tweaking 19 29-06-07 08:41 PM
bike lowering jim@55 SV Ecosse 16 22-08-06 04:49 PM
