Old 29-04-10, 12:28 PM   #1
ChromeQ
Default Speedo problem on sv650
Hello, I am newly registered here on the forums but have been using it in the past to answer any problems iv had in the past. Just want to say hello whilst im here with a unusual problem. I have been an SV rider since last february, it is my first bike and so far all good, mostly used for commuting and the weekend ride out,,
Have a problem on SV650 started last night on the way home from work, the speedometer suddenly started displaying random numbers, anything between 0 and 20 mph and it will jump changing constantly making no difference if i was riding fast, slow, any gear or rpm.
The odometer is not counting properly, i suspect its linked to the speedo and time since i completed a 20 mile commute today and it counted as 1!
I dont know where to start on this one, i suspect either a loose connection or a sensor is on the blink. I assume to avoid tampering it will not be an easy to see and reach plug connector!?
Any light you can shed would be great, i just got it serviced last weekend and will be back to get my book stamped so will ask the garage whilst im there but if i can fix it myself then even better.
Old 29-04-10, 12:36 PM   #2
simesb
Default Re: Speedo problem on sv650
First thing I'd check is the speedo magnet on the front axle. If they break (and they seem to be made of glass) your speedo reading can go all over the place.
Old 29-04-10, 04:00 PM   #3
Jayneflakes
Jayneflakes's Avatar
Speedo magnet is a real weak spot, mine had the tabs fall off, but a dab of Araldite soon had it fixed and back together, speedo working fine again.
Jayne you're a Pussy Magnet
Old 29-04-10, 04:40 PM   #4
barwel1992
speedo rotor has most likely gone
get a new one about £25 from a dealer
put bike on paddock stands drop the front wheel (1 bolt (12mm) and a 20mm alen key for the axle) slide axle out and the sensor is on the right hand side when facing the bike, remove wheel (be careful of disks in the callipers still you might bend them if the ain't out fully) sensor will still be attached to the wire and dangling off the forks
Part 15 is the bit that will most likle be broken and will look at bit like this (bottom one is broken top is new and fine) remove this and clean the cup where it sits in
slot new rotor (part 15) in to part 14 (the sensor bit that dangle off the forks) and carefully line the 4 prong up with the slots in the wheel
make sure every thing is clean before reassembly
Old 29-04-10, 04:55 PM   #5
punyXpress
punyXpress's Avatar
Don't do anything until you've spoken to your garage, hinting that it only started when you rode home.
Let them fix it for free!
Now: Street Triple R
Old 29-04-10, 05:14 PM   #6
Dicky Ticker
If for any reason the front axle has been overtightened this can cause speedo problems,so if the garage did anything with the front spindle it COULD be they are at fault,but there does seem to be a common fault on the sender unit
Speedo problem ian505050 Bikes - Talk & Issues 12 22-11-09 03:14 PM
Speedo problem. Giggsy SV Talk, Tuning & Tweaking 11 19-02-09 06:13 PM
SV650 speedo in km, problem? Feldspar SV Talk, Tuning & Tweaking 8 17-08-08 10:14 AM
Speedo Problem....HELP! SAMMY650 Bikes - Talk & Issues 0 09-05-08 12:27 PM
HELP speedo problem M.C. SV Talk, Tuning & Tweaking 15 17-07-05 02:18 PM
