Old 29-04-10, 08:54 PM   #1
Paul1984
Default www.998cc.co.uk risers
Of all of you that have fitted the suzuki comfit kit from 998cc,if you were a complete novice would you have found it easy.Are there instructions in the pack as it does not say.Looks like it is worth the money
Old 29-04-10, 08:55 PM   #2
Sean_C
Default Re: www.998cc.co.uk risers
**** easy. Can't remember if there are instructions, but if there aren't, you really don't need them.
Old 29-04-10, 09:41 PM   #3
danf1234
Can you elaborate on that please because I am interested too.
Old 29-04-10, 09:42 PM   #4
Paul1984
I have ordered it and hope it is easy,any help would be great
Old 29-04-10, 10:10 PM   #5
barwel1992
as long as you can bleed brakes then there's nothing more to it realy other than a few bolts
Old 29-04-10, 10:19 PM   #6
danf1234
What is involved with fitting longer cables and re-routing cables.
Old 30-04-10, 03:46 PM   #7
I found the throttle cables a bit fiddly tbh but apart from that ok.
No instructions came with mine either, dont know why?
Surely a 'kit' shoould provide some instructions of some sort.
Old 23-06-10, 09:29 PM   #8
Paul1984
Hi guys want to bump this thread,I took the bike to a mechanic today to fit the streetfighter kit,but he phoned saying the brake lines are too long has anyone else had this problem,or is the mechanic doing something wrong.Should I just use original cables.
Old 23-06-10, 09:32 PM   #9
Your originals wont work.
Unless they are stupidly long they should be ok, i have left my braided ones on and put my original clip on set up back on and they are ok.
Old 23-06-10, 10:40 PM   #10
Luckypants
Luckypants's Avatar
I fitted the same kit to Speedy Claire's bike at the weekend and yes the supplied lines are a bit long, but not to long. I have them in a graceful curve and all looks good, they do not obscure or foul anything.
One thing to note is that the line to go to the left calliper is slightly longer than the one to the right, if he offered up the long one to the right calliper it would appear to be much to long. Just ask him if he is aware of that.
Specialone - Just realised I still owe you a PM reply mate!
998cc.com comfort kit maff Idle Banter 0 04-11-09 11:24 AM
Bar Risers cammy SV Talk, Tuning & Tweaking 2 26-04-09 12:16 PM
bar risers wow SV Talk, Tuning & Tweaking 14 19-06-08 06:16 AM
Bar Risers 600+ Bikes - Talk & Issues 0 13-05-08 05:04 AM
Sun Risers scousegit SV Talk, Tuning & Tweaking 5 14-06-05 11:28 AM
