Just been grabbing a few new parts from wemoto.com (very useful site for direct replacement parts for your exact bike) and i noticed in the sprocket section theire is a list:
Front Sprocket: Standard Less 1 tooth Less 2 teeth Plus 1 tooth Plus 2 teeth Rear Sprocket: Standard Plus 1 tooth Plus 2 teeth Plus 3 teeth What is the general difference in adding or removing a tooth? And what would be an adverage ratio (for tweeking purposes) Last edited by Nosfertau; 01-05-10 at 09:11 AM. |
#2 | |
you sometimes find yourself trying to change into 6th gear when you are already there, and you use a little bit more fuel, but you get used to being at higher revs when on a high speed cruise, and you get used to it. |
Ace, well thankyou for that -Ralph-, i'll be ordering a new sprocket then, could do with a little better acceleration. feel sometimes im just not going anywhere lol Cheers again.
I was wondering the same thing.
So more teeth on back sprocket = more acceleration, more front teeth on front sprocket = ? |
gearingcommander.com to see differences in rpm at given speeds
Nice site
#7 | |
Less teeth on back or more teeth on front = higher gearing Higher gearing may be beneficial if you are looking to reduce revs for a more relaxed cruising speed (and possibly better economy but this would depend on the bike) but on an SV it would not increase top speed as it cannot rev to the limiter in top gear. Power is the limitation, not the gearing. On a bike that can rev to the limiter you would increase or decrease top speed, until your gearing gets so high that the bike doesn't have the power to pull to the limiter any more. I've never heard of someone using higher gearing on an SV and I don't know why you'd want to do it. |
You never had meccano when you were a kid did you
#9 |
Going down one tooth on the front is the same as going up about 2.5 teeth at the rear and Vise Versa.
The original gearing on my 600 gixer is 16/45. I'm presently running 15/47 and it'll wheelie on the throttle in first second and third. ![]() For the next race I'm running 14/47 and may just struggle to keep the front on the tarmac at all :O) Unless you have a speedo thats geared from the front wheel, changing the sprockets will make the speedo read wrong. C |
#10 |
I just changed my front Sprocket for a 14 tooth one. Change isn't as drastic as I had hoped for.
So now going up 3 on the Rear. Will let you know the results. I'll be running 14/48 in the end. Standard 15/45. I have been told that I will need to replace the chain for one with an extra 2 links(112). Hopefully my bike will be as wheelie happy as Berlin's ![]() Last edited by hollayzfr1; 01-05-10 at 06:38 PM. |
Hen's teeth? Anyone got a transponder for sale? | lukemillar | Mini-Twins | 1 | 09-03-10 12:09 AM |
Broken off gear teeth? | defiant | SV Talk, Tuning & Tweaking | 24 | 08-12-08 08:32 PM |
Fewer or less... | BillyC | Idle Banter | 45 | 04-09-08 01:35 PM |
My teeth are falling out :( | gettin2dizzy | Idle Banter | 19 | 26-05-07 09:59 AM |
